ohlins vs progressive
Old Aug 3, 2014 | 01:09 PM
  #141
Dun Roamin's Avatar
Dun Roamin
That bracket is for the twin protection crash bars, is it? And you don't use them?
I think I'd be tempted to cut and grind it off, when it comes to your winter rebuild of the set up, and free yourself up a little bit as to where you are placing the reservoirs. If you never want to use the bit old retro saddle bag guards, that is.
At least it's only the saddle bag support bar ... Take them off, have them sand blasted, de-nib and wire brush them, cut the bracket off and then, may be, weld on two small tabs to the mount the Ohlin reservoirs.
If Ohlins don't do a reservoir with tabs, I'd be tempted to think of making up something like a clutch cable stay to them clamp them in place.
Something like one of these, but bigger ...
You would not need tabs, you could just clamp it in place, but tabs would hold it better and more easily off to the side, away from anything moving (just some loose thoughts as I cannot actually see one in front of me).
Alternatively. you could have a 90 degree bracket that was clamped into place by the black cap of the reservoir ... but it would not be so strong.
I'd agree you need another inch or so, that top curve looks a little tight to me. I am sure it won't be a problem but it would look better a little more relaxed.
What fittings do the pipes use ... typical AN-3? Are they standard teflon lined oil or brake lines?
Tending towards perfectionism on these things, I'd say something with a 20 degree fitting on the top might sort it out a little better.
Over to the Metal Meister now ...
Old Aug 3, 2014 | 01:36 PM
  #142
tj316's Avatar
tj316
On my 2011 FLTRX I mounted them below the bar , it fit better , on the side with the antenna bracket I used one of the supplied L brackets , I lined it up and drilled holes in it to match the bracket holes and mounted it there
Old Aug 3, 2014 | 01:38 PM
  #143
tj316's Avatar
tj316
Here's the other side
Old Aug 3, 2014 | 01:40 PM
  #144
tj316's Avatar
tj316
The left side again
Old Aug 3, 2014 | 02:52 PM
  #145
SeaZund's Avatar
SeaZund
any pictures of these mounted on a pre-09 bagger frame?
Old Aug 3, 2014 | 06:26 PM
  #146
FastHarley's Avatar
FastHarley
Former Sponsor
Default answers
Every one of the last several questions have been answered above including pictures.
Old Aug 3, 2014 | 10:09 PM
  #147
Zeus55's Avatar
Zeus55
Thanks for the pictures... it gives a very good idea on how and where to install.
Old Aug 4, 2014 | 02:47 AM
  #148
Dun Roamin's Avatar
Dun Roamin
My apologies ... I'll go do my homework and read the last 15 pages now.
For those interested in doing so, I found the text only print version makes it easier.
Quickly, I don't see any mention of braided line length. Is that on Howard's website or Ohlin's own page?
Old Aug 5, 2014 | 06:08 AM
  #149
GungHo-HD's Avatar
GungHo-HD
Yes, the bracket is for the twin protection crash bars which I have no intentions on ever using.
I strongly agree.
I have no idea what type of fittings that they are. I do like your idea of using a 20 degree to get the angle perfect.
I also like the idea of the chrome heavy duty clamps or a billet aluminum. I think it would be much better than tape and hose clamps.
Old Aug 5, 2014 | 08:41 AM
  #150
Dun Roamin's Avatar
Dun Roamin
What diameter are the reservoirs?
Likely it is a fairly standard metric size and something already exists to fit it in the sports bike world.
I did a Google for 'shock absorber reservoirs clamps' or 'Shock Canister Mount' images and came up with quite a few.
For example ...
From mattsclassicbowties.com ...
I'm guessing you could find something to your taste or easily mod one. There's a few also for Arctic Cats or even whip mounts for UTVs. All it takes sometimes is to step back and do a little lateral thinking.
I agree with you that worm gear clamps and tape are just not good enough on a product and bike that expensive and that classy.
