Missing Neutral.....
Old Apr 9, 2012 | 01:02 PM
FUBAR55's Avatar
FUBAR55
Spectro Platinum has always worked for me and I can get it locally.
Good Luck.
Old Apr 9, 2012 | 01:07 PM
Paradise Lost's Avatar
Paradise Lost
Thanks, FUBAR55!
Old Apr 9, 2012 | 01:08 PM
103 sedona orange's Avatar
103 sedona orange
I run Redline ShoockProof tranny oil. There are other good tranny fluids out there also.
Old Apr 9, 2012 | 01:19 PM
aces25's Avatar
aces25
I went to Bel-Ray 85W-140 on the 1k service and neutral is much easier to find now. Clunking during shifting is greatly reduced as well. Redline Shock Proof Heavy (SPH) is also thought of highly around the forum.
Old Apr 9, 2012 | 01:40 PM
Paradise Lost
Thanks 103 sedona orange and aces25!!!!
Old Apr 9, 2012 | 01:44 PM
rhlhamlet's Avatar
rhlhamlet
Probably one of the most asked questions on this forum and the easiest answered of all... Experience.
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
If you are using the heel shifter, it is common to have neutral be a pain in the ***. Try moving the toe shifter up so you can use it until your tranny gets broken in. It's easier to find neutral with your toe.
Old Apr 9, 2012 | 02:48 PM
jbkrab's Avatar
jbkrab
Had the very same issue on my 2011 FLHTK. It was suggest to me on this forum that until I do the first adjustment and change out the oil (I used RedLine) to place the arch of my foot/boot over the pivot of the heel/toe shifter and gently go from 1st to Neutral or 2nd to neutral by putting slight pressure onto the front or rear lever. It works and then when I did that fluid change and clutch adjustment, all has been perfect ever since.
Old Apr 9, 2012 | 02:57 PM
teedubya's Avatar
teedubya
Had the same issue on both the '10 Ultra as well as the current '11 Limited. A clutch adjustment helped along with the fluid change but time and mileage made the biggest difference.
Old Apr 9, 2012 | 02:58 PM
Jeffs386's Avatar
Jeffs386
mine used to miss neutral once in a while but I recently put Spectro Platinum 6 spd in the trans and so far its been awesome,no 1st gear clunk and neutral is always right there!
