Missing Neutral.....
Old Apr 9, 2012 | 06:52 PM
wardawg1's Avatar
wardawg1
Almost impossible on my 2012 SG to find neutral....Once I shut the bike off it slips right into N first try but when it's running, not a chance, takes me forever to find.
Old Apr 9, 2012 | 07:18 PM
Rick Lees's Avatar
Rick Lees
It gets easier and you will get better at it..... mine I just use my heal to lightly tap down after its in 1st you'll get it it just tight and your frustrated
Old Apr 9, 2012 | 07:24 PM
jcurley290's Avatar
jcurley290
Have the same problem
Old Apr 9, 2012 | 07:27 PM
banddirector's Avatar
banddirector
Had the same problem with the bike when it was new, but now a year and 15K miles later it's a lot easier. Don't know if it's just broke in now or I'm getting better at it ...
Old Apr 9, 2012 | 08:15 PM
1HarleyGuy1's Avatar
1HarleyGuy1
I never had a great deal of problem with mine. It would be a bit finicky from time to time but nothing serious.
Then the original shifter linkage failed and I installed a billet HD one with the Heim joints.
That made a HUGE difference. "Tightened" up the whole shifting system.
1HarleyGuy1
Old Apr 9, 2012 | 08:34 PM
Guntoter's Avatar
Guntoter
Overfilled primary will also cause hard to find neutral.
Old Apr 9, 2012 | 08:37 PM
vet767's Avatar
vet767
I read AIM and keep hearing Chris say the same thing. I have a 99 sporty, 03 lorider and an 08 roadking. Of the three, the RK is by far the easiest to hit neutral, a little bump and it's in. Maybe you guys need to caress it up instead of trying to bang it in? Then again, maybe you need to loose the heel shifter. POS imo
Old Apr 9, 2012 | 08:54 PM
Lantern's Avatar
Lantern
#1 Redline will do the trick.
Old Apr 9, 2012 | 09:03 PM
Lantern's Avatar
Lantern
Old Apr 9, 2012 | 09:16 PM
Troubleman's Avatar
Troubleman
I found that the heel shifter works best for me. Like said earlier, drop it if first, then a light tap with your heel usually does it.
