107 or 110 big bore kit
Old Apr 9, 2012 | 08:06 PM
bubbarh1212's Avatar
bubbarh1212
Default 107 or 110 big bore kit
ok guys I am new at this but I have some money burning a hole in my pocket and what to do the the big bore kit should I do the 107 or 110 and what kind do you recommend ? is there a good place to get them ??
Old Apr 9, 2012 | 08:29 PM
DBAGR's Avatar
DBAGR
The 107 can be done without boring the cases which means you don't have to pull the engine to split the cases, so if you have decided on one of the two (107 or 110) the 107 is far more practical. 3 cu in is not worth money spent, so if you are willing to spend to bore cases you may as well go to 117 or more. Hillsidecycle.com would be a good place to start.
Old Apr 9, 2012 | 08:32 PM
bubbarh1212
do you have any idea what the 107 costs
Old Apr 9, 2012 | 08:37 PM
boston joe's Avatar
boston joe
Cost me around 2500 ish not including exhuast,tuner and dyno wrenched it too.. Check out fuel Moto or ur local indy
Old Apr 9, 2012 | 08:58 PM
VTL nut's Avatar
VTL nut
http://fuelmotousa.com/107kit.htm
Old Apr 9, 2012 | 09:05 PM
skratch's Avatar
skratch
depends on what your definition of 'some' is. is it 2,000? or 10,000? the former, then go with the 107. the latter, skip the engine mod and get you a cvo
Old Apr 9, 2012 | 09:10 PM
bubbarh1212
yes sir I had no clue it cost upwards of $2500 to do the 107 thinking about skipping this I am thinking the 103 is enough for now lol
Old Apr 9, 2012 | 09:44 PM
jeff.georgalas's Avatar
jeff.georgalas
The 103" kit if you Have Harley do the work and include cams will cost you more than the 107" kit. You REALLY need to do some research on your own here.
Old Apr 9, 2012 | 10:31 PM
bubbarh1212
I am sorry I didn't say that correct I already have the 103 right now I have a 2011 ultra limited with the 103 so I was saying I may leave it the way it is
Old Apr 9, 2012 | 10:38 PM
jeff.georgalas
If you don't want to spend "that much" money, just do cams for now, and that will give you a bump of about 17 HP and 15 TQ. At least that's what I got from just changing my cams. Of course it depends on which cams you choose and who dyno's the bike for you as well.
