Larger Throttle Body
Old Dec 30, 2006 | 12:49 PM
Bryan TTM's Avatar
Bryan TTM
Default RE: Larger Throttle Body
i thought 26g's were andrews cams...not kuryakyn....whatcha got combo wise jeepster
Old Dec 30, 2006 | 01:08 PM
jeepster09's Avatar
jeepster09
I am basicly running the Kuryakyn Crusher Package with a few deviations.
[ul][*]Kuryakyn 26G cam[*]Ported stock heads with bigger valves and Kuryakyn spring kit. Heads are cc'd same and using a true .030 quench with Cometic gaskits.[*]Kuryakyn hi-compression forged pistons 10.44 to 1 ratio.[*]S.E.Race Tuner[*]Left side crankshaft reinforcing kit.[*]Super Trapp Super Megs 2 into 1 exhaust.[*]V.P.C. clutch pressure plate with S.E. spring.[*]Oil cooler.[*]57 mm Kuryakyn Throttle Body.[/ul]
The bike runs fantastic and is used at low speeds as well in parades and for crowd control. Point being agood all around combo that works to kick A$$ and cruising or touring. The whole package runs great on 91 octane with NO PINGING.[Thanks to the expert tuning of Mike Rolland at World Class Tuning]I did not use the Kuryakyn Billet Heads in the Crusher Package due to cost and am not dissapointed. I tried a lot of combo's and wish I would of done this one first, it would of saved me a ton of money.
http://www.kuryakyn.com/wtproducts.a...gn=Dyno+Charts
[IMG]local://upfiles/1346/FFE20583A1594F7E80A5FC80FC0EBACC.jpg[/IMG]
[IMG]local://upfiles/1346/A5F1765FE38241FA8860DDA24D535A42.jpg[/IMG]
Old Dec 30, 2006 | 01:51 PM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: jeepster09
[ P.S. they are Kuryakyn 26G cams and not Andrew's.]
Maybe to clear up any future confusion...............you could put TC-26G cams or Wild Things TC-26G cams.
Just a thought.
Steve
Old Dec 30, 2006 | 03:06 PM
turbo54's Avatar
turbo54
Good thread, Im running 42 mm on a MM throttle body , It,s been a night mare tuning my bike with the Pc 3 after trashing 3 pc I e mailed Jamie and his reply was the pc 3 is not equipped to tune a non stock throttle body , I had to go with a sert so much better.
[IMG]local://upfiles/3159/318289B2FD3746DB82B6453E39529525.jpg[/IMG]
Old Dec 30, 2006 | 03:11 PM
turbo54's Avatar
turbo54
For those that don't know Jamie he it the rep for Dyno jet research.
Harleypaw's Avatar
Harleypaw
Who told you the PC was not made to tune larger TB's
I've run PC with every EFI i've owned and have never run a stock TB, or at least not very long, and haven't had any problems tuning.
Old Dec 30, 2006 | 03:30 PM
turbo54's Avatar
turbo54
I found the letter fuelmoto Ill try to post it latter on .
Old Dec 30, 2006 | 03:35 PM
turbo54's Avatar
turbo54
Wops It read there custom maps are done with stock TB, They did not say it couldn't be tuned .
Old Dec 30, 2006 | 03:58 PM
maineultraclassic
Now about that [sm=nxsmile.gif] what kind of cost is involved with a small kit?
Does it do as much damage as everyone says, even when used in moderation with small shots?
Steve
Old Dec 30, 2006 | 04:14 PM
Harleypaw's Avatar
Harleypaw
I would stay away from the NOS without some bottom end work.
