Braided Brake Lines on StreetGlide
Subscribe
Apr 11, 2012 | 11:49 AM
Cant seem to find the answer on this by myself so posting up the question.
I want to switch out the front brake lines on my StreetGlide for braided stainless steel lines. Just the bottom lines, not the entire system.
Does anyone know if these are available with out switching out the entire front brake line system?
thanks!
Reply 0
Apr 11, 2012 | 11:52 AM
If you have ABS I believe you can do it. If you dont have ABS you will have the replace the entire line from lever to caliper
Reply 0
Apr 11, 2012 | 11:56 AM
On my 07 the 2 lines go from the caliper to a junction mounted on the trees. If your system is like this I wouldnt see why you couldn't. I went braided and it was just like the stock set up.
Reply 0
Apr 11, 2012 | 11:57 AM
Quote: If you have ABS I believe you can do it. If you dont have ABS you will have the replace the entire line from lever to caliper
Its a 2010 with ABS. Just want to replace the short cable from the caliper up to the bottom fork bridge.
Reply 0
Apr 11, 2012 | 11:59 AM
Quote: On my 07 the 2 lines go from the caliper to a junction mounted on the trees. If your system is like this I wouldnt see why you couldn't. I went braided and it was just like the stock set up.
Yep, just want to replace the short ones from the caliper to the junction.
Did you replace your entire system or just the bottom lines? HD parts or aftermarket, doesnt matter to me.
Reply 0
Apr 11, 2012 | 12:09 PM
Quote: Yep, just want to replace the short ones from the caliper to the junction.
Follow the link below it should give you everything you asked for and more.
http://www.magnumshielding.com/store...2010&x=53&y=12
Reply 0
Yes I had to replace whole system because I changed the bars. I went aftermaket got em from directharleyparts. The banjo bolts are the same size as the stock ones. You should be able to bolt the new lines into your stock junction block
Reply 0
Apr 11, 2012 | 12:32 PM
Call J&P cycles. They are a sponsor and will give you all they part #'s you need. I did it with online chat from there website.
Reply 0
Explore
Apr 11, 2012 | 12:54 PM
Quote: Its a 2010 with ABS. Just want to replace the short cable from the caliper up to the bottom fork bridge.
Sent you a PM
Reply 0
Apr 11, 2012 | 01:24 PM
Negative...You need to replace from the calipers to the the manifold to the ABS block under the left side cover.
Replacing the lines into the manifold isn't an option, unless you go with a build your own kit.
Magnum makes a stainless and sterling chromite II option for just the lower. It's $165.
Reply 0
Subscribe
