07 FLHT battery replacement
Old Apr 16, 2012 | 11:25 PM
ghostrider45's Avatar
ghostrider45
Default 07 FLHT battery replacement
I have a new battery to install in my 2007 electra glide standard. Can someone point me to the proper order to disarm the bike and remove the battery? The owner's manual doesn't have that info (at least not that I could see).
The ignition needs to be on to disarm, but disconnecting the battery with everything powered up seems wrong.
thanks
~ghostrider45~
Old Apr 16, 2012 | 11:31 PM
hog-doc's Avatar
hog-doc
Just have the FOB with you!
Old Apr 16, 2012 | 11:36 PM
Potato_Potato's Avatar
Potato_Potato
Ya, and the ignition off.
Old Apr 16, 2012 | 11:39 PM
hog-doc's Avatar
hog-doc
That should have gone with out saying!
Old Apr 16, 2012 | 11:43 PM
ghostrider45
With the ignition off the key symbol continues to flash indicating the bike is armed.
that's why I'm confused
Old Apr 17, 2012 | 09:15 AM
X Iron Butt's Avatar
X Iron Butt
Ignition OFF disconect neg first. When putting in new battery connect pos first. Unless you have an HD audible alarm that has an internal battery you won't know the difference FOB in hand or not. The signal lights can't flash if battery is disconected.
Old Apr 17, 2012 | 11:19 AM
hdramon07's Avatar
hdramon07
Key fob present>>ignition on>>Pull Maxi Fuse>>ignition off>>change battery>>re-install maxi fuse.
Old Apr 17, 2012 | 11:02 PM
ghostrider45
thanks guys.
I called the local Harley dealer and after some consultation they said just leave the ignition off and pull the battery. That's what I did and it works fine.
Derf_
Oct 9, 2019 05:36 PM
walkerinin
Nov 21, 2016 09:08 AM
Asclepeus
Aug 11, 2012 08:21 PM
RafiHarley_1903
Jun 22, 2010 07:16 PM
devo
Aug 12, 2009 04:15 AM
