Exaust Gaskets
Old Apr 17, 2012 | 01:38 PM
heritagehawg's Avatar
heritagehawg
I installed power duals last week used the supplied gaskets.. now I have an exhaust leak from the front cylinder.. should I replace them with the SE gaskets?
Old Apr 18, 2012 | 04:16 PM
mrfikser's Avatar
mrfikser
I had the same problem...and took the whole thing back off....there was nothing wrong with the gaskets....you prolly need to just retighten them....
Old Apr 18, 2012 | 04:30 PM
Gunnysgt's Avatar
Gunnysgt
Ditto, V&H normally recommends the SE gaskets on their pipes. I use a small 90 degree pick to pull out the old ones. Clean the area around the port with lacquer thinner of similar solvent then seat the new SE gasket in evenly. Don't overtorque the bolts.
Old Apr 18, 2012 | 04:31 PM
txfxstrider's Avatar
txfxstrider
I have frequently heard that the stock HD gaskets work better than the SE ones. I believe one is round and the other has a shoulder. From experience, I know that either work. Most leaks occur from improperly tightened headers.
Ausreed93
Exhaust System Topics
Feb 13, 2018 12:07 PM
OneTrashyDyna
Jul 8, 2015 08:45 PM
hoethree
Feb 9, 2011 09:50 AM
marinepilot81
Jul 17, 2010 02:53 PM
OneBlackFly
Jul 18, 2008 02:41 PM
