Indexing spark plug washer sizing....
Old Apr 18, 2012 | 08:26 PM
nvsteve's Avatar
nvsteve
Originally Posted by hog-doc
Unless your running 12:1+ compression and 2-3 hp per cubic inch you wont see a benifit.
Source please.
Old Apr 18, 2012 | 08:46 PM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
Originally Posted by nvsteve
Source please.
High compression motors hide the electrode (so to speak) from the combustion chamber when the piston comes to TDC because of the dome of the piston. By turning the electrode towards the intake valve you are exposing the most intense part of the spark to the majority of the fuel mixture. Most of the increase in power comes from the fast, even burn of the charge. In any other motor your likely to see less then 3% of an increase in power.
As far as a source, the attachment I have in PDF form is too large or I would post it here. Send me an e-mail and I will send it to you.
Also, for whatever it is worth, I index the plugs in both of my bikes and do it with the crush washers from old plugs. I know, I know, heat transfer and whatever. Never had a problem with tune of a motor. Been in Phoenix in summer and Northern Michigan in winter.
Old Apr 18, 2012 | 09:15 PM
journeyman's Avatar
journeyman
Tough crowd
http://www.nrhsperformance.com/partsignition.shtml
Item# 33-372029
Old Apr 18, 2012 | 10:07 PM
fabrik8r's Avatar
fabrik8r
Originally Posted by TUCCI
I was under the impression the electrode needed to be pointed at the intake valve
...however the pics below shows it pointed in the middle of the valves:
perhaps fabrik8r could assist with explaining which was the electrode should be pointed to have the plugs properly indexed....?
I won't commit to knowing what's proper, but I aim for the intake valve, that's about 4-5'oclock on the rear cyl, and about 7-8 'oclock on the front cylinder, using the same marking/ ground strap orientation technique as above. The bottom pic chamber view is "correct", but it doesn't match the top pic above deck view.
Old Apr 18, 2012 | 11:37 PM
mike_oh's Avatar
mike_oh
Got mine from Bishops. Google Bishops Indexing washers maybe..... They were cheap and why not try them.
Old Apr 19, 2012 | 07:47 AM
TUCCI's Avatar
TUCCI
Thanks for the input everyone...going to index regardless, just makes sense pointing the plug in the right direction especially if the plug your using only has one grounding strap. I suppose if I were using a plug with four straps one or more would be pointing at the intake? But since I dont read much about those plugs being used much its best to keep it simple.....take care, Tucci
Old Apr 19, 2012 | 08:03 AM
racklefratz's Avatar
racklefratz
First I've ever even heard of this. Maybe it's because I don't have much experience with racing and high performance stuff - dunno. But if there really was all that much to be gained from such a simple idea, it does seem that it would be common knowledge everywhere.
Old Apr 19, 2012 | 08:30 AM
X Iron Butt's Avatar
X Iron Butt
I won't claim to be an expert either but in theory the main idea is to not have the ground strap in the way of the flame front towards the center of the combustion chamber. Picture one does that within the green arrows. The air/fuel coming into the cylinder should be flowing down with piston in all but the valve overlap portion at the beginning of the intake cycle where there would be intake air flow across the plug to the exhaust valve. Any flow across the plug is very short duration but will still tend to clean the plug without interference/turbulence from the ground strap when oriented this way. I would say 90* would be optimal and do not really understand any advantage of having it point toward the intake valve as it has been closed for almost the entire compression stroke when the plug fires.
These heads are also no longer Hemi design and having a squish area should (by design) cause turbulence in the combustion chamber away from the wider edge of the bathtub shape as the piston approaches TDC.
Old Apr 19, 2012 | 09:11 AM
journeyman's Avatar
journeyman
Another non-expert here,
the way I always thought of it was, that it had nothing to do with the flame or combustion at all, but rather, the whoosh of clean fuel/air sweeping across the entire electrode for cleaning and cooling as the whole point.
Where as if the ground strap blocked the incoming clean fuel/air, deposits and uneven cooling of the plug would occur, slightly but more.
Nothing lost, (except spacer cost) something possibly gained.
Old Apr 19, 2012 | 09:50 AM
fabrik8r's Avatar
fabrik8r
I'm in agreement, theoretical precise alignment is not as important as just making sure the ground strap is not creating a shrouding condition. There is a pretty wide range of positions that will allow an unshrouded spark with direct access to the combustion chamber. However, it takes about the same amount of time and effort to go ahead and point them at the center of the intake valve. The only reason I go ahead with the precise alignment is I have observed my plugs when not pointed directly at the intake valve, but they were stiil in a mostly unshrouded position; I saw a carbon "shadow" built up behind the shrouded side of the ground strap, but a plug pointed directly at the intake valve will remain thoroughly clean. I don't remember where I read it or the application but somewhere I recall mention of facing toward the exhaust valve in a hemispherical head design, maybe it was a dual spark application to promote waste gas burn off.
