Oh well, since the plugs are going to be in the heads for an indefinite time frame, installing them any which way just doesnt make sense. It may be a complete waste of time, but Im one of those that still coats an oil filter gasket with oil off my fingertip. Whose to say?
Just put my plugs in and they lined up pretty close to 4-5 and 7-8. Was able to tighten them to right at 12 ft lbs maybe just a little less but the stock plugs were very loose.
A highly flexible term commonly used by the English.
1. something rubbish
2. a falsehood or series of lies
3. something great
4. the best possible
5. *********
6. exclamation on making a error.
Let me clarify it.
In the real world it'll make no difference which angle you fit your plugs, unless some comes up with a dyno run which proves me wrong.
Any takers?
Let me clarify it.
Any takers?
On flat top pistons, no squish band, I would have to agree, not much of a difference. On a 74 XLCH that I have, if not indexed, or side gapped, you can feel the difference. That has a domed piston and should really be double plugged. Of course the merits of that I have seen argued over for countless threads and such.
This is not a H/D motor, but here it is anyway;
