Oil Change question
Old Dec 31, 2006 | 12:29 PM
1flhtk4me's Avatar
1flhtk4me
Default RE: Oil Change question
I used the white stuff because it was on the threads when I did my first service.Had no problems with it.
Old Dec 31, 2006 | 12:40 PM
oscarg's Avatar
oscarg
Do you need a jack or anything special to do a oil change on a 07 ultra
Old Dec 31, 2006 | 12:44 PM
04RoadKing's Avatar
04RoadKing
ORIGINAL: 1FLTRI4ME
The sealant was on the plugs from the factory or the dealer(dealer did the 1K).
Why is it not a good idea?
BTW,I'm not reffering to red,blue or any Loctite that is for holding. It's the white stuff.
First off I wouldn't want to chance using any kind of loctite at all on any nut or bolt that treds into my engine. Can you imagine if it gets into the engine oil.
The service manual does not say to use any kind of loctite at all on the trany or engine drain plugs, just check o-rings and replace if need then install drain plugs and tighten to 14-21 ft-lbs. The Primary would be the same inspect drain plug for cuts or tears and replace as necessary then tighten plug to 30-60 in-lbs
Old Dec 31, 2006 | 12:51 PM
1flhtk4me's Avatar
1flhtk4me
OK,you make a good point.
Old Dec 31, 2006 | 01:36 PM
berettag's Avatar
berettag
Keep in mind when you screw the oil filter off you gotta put something under it to keep it from draining all over your frame. I use the flattened cardboard box the filter came in and channel the oil into the drian pan.
Old Jan 1, 2007 | 07:36 PM
norskehd's Avatar
norskehd
I purchased a HD Service Manual from Cycle Manuals Inc. (cyclemanual.com) - $54.95 + $4.00 shipping. HD part manual for touring models is 99843-07 for an 07 - (on the HD web page the manual is listed for $58.00). I don't plan on any major do-it-yourself repairs - just like to see how it is put together and may help with some "small" tasks. Earlier years the last 2 numbers are the model year. So - - on page 7-30 of the manual (transmission section) it shows a baffle in the pan. It appears to separate the enginefluid from the transmission fluid. Some good pictures on page 3-13(engine section of the manual).
Old Jan 1, 2007 | 08:04 PM
dgriffith's Avatar
dgriffith
I reguards to the white liquid thread sealer, it would not hurt anything .The industrial machinery builders and hydraulic co. have been using it for years. It will mix with most oils and will not hurt anything, but that white tapestuff is a no no. it can stop up a filter or a oil passage.. 35+ yrs as a precision machine rebuilder/ repairman. Cummins Inc.
Old Jan 1, 2007 | 08:30 PM
Longtimegone's Avatar
Longtimegone
ORIGINAL: 04RoadKing
ORIGINAL: 1FLTRI4ME
You guys should really take another look at your service manual. Seems nobody is getting even close. No loctite, no tape on your crankcase or tranny - only o-rings. The primary plug gets tape, but should only be screwed in until .05" of the plug is still out. You do not want to tighten it. The service manual will be a good investment.
Old Jan 1, 2007 | 09:40 PM
StreetGlide2006's Avatar
StreetGlide2006
ORIGINAL: berettag
I use a sheet of the misses tin foil, it can be molded right under the filter and the oil runs into the pan.
Ride Safe,
Mike
Old Jan 1, 2007 | 10:04 PM
TexasRedneck's Avatar
TexasRedneck
ORIGINAL: StreetGlide2006
Haven't done the 5k service on mah UC yet (only had it 'bout 7 weeks now), but when I do, ah'm gonna fab me a drain pan that'll fit under the filter an' take the drips into the drain bucket. Ah HATE dripped oil on anythang mechanical.
