Oil Change question
Old Jan 5, 2007 | 01:02 AM
  #31
Longtimegone's Avatar
Longtimegone
Default RE: Oil Change question
ORIGINAL: 04RoadKing
ORIGINAL: Longtimegone
ORIGINAL: 1FLTRI4ME
The sealant was on the plugs from the factory or the dealer(dealer did the 1K).
Why is it not a good idea?
BTW,I'm not reffering to red,blue or any Loctite that is for holding. It's the white stuff.
First off I wouldn't want to chance using any kind of loctite at all on any nut or bolt that treds into my engine. Can you imagine if it gets into the engine oil.
The service manual does not say to use any kind of loctite at all on the trany or engine drain plugs, just check o-rings and replace if need then install drain plugs and tighten to 14-21 ft-lbs. The Primary would be the same inspect drain plug for cuts or tears and replace as necessary then tighten plug to 30-60 in-lbs
You guys should really take another look at your service manual. Seems nobody is getting even close. No loctite, no tape on your crankcase or tranny - only o-rings. The primary plug gets tape, but should only be screwed in until .05" of the plug is still out. You do not want to tighten it. The service manual will be a good investment.
Don't know what service manual your looking at but mine doesn't say anything about tape on the primary plugand only screwing in.05".
Mine say's just as I stated above .
Inspect drain plug for cuts, tears or signs of deterioration. Replace as necessary. Install drain plug back into primary chaincase cover. Tighten plug to 36-60 in-lbs.
Page 1-17
Reading the service manual would be an even better investment.
Yep, only screw the primary drain plug in to where .160" -.180" is still outside the casing for an 03 Touring. Sorry 'bout that. I forgot he was asking about an 06. I still suggest a H-D service manual for your specific bike.
BTW, 04RoadKing, you got some smarts running through your veins. That's cool. Maybe I do , too. Thanks for settin' me straight.
Ride Safe....
rossn2
Dec 26, 2014 06:46 AM
bubdifab
Jul 17, 2013 06:52 PM
HD Pilot
Oil Archive (no new posts)
Apr 10, 2013 08:25 PM
nh-trekker
Aug 12, 2012 06:22 PM
Patch
Aug 1, 2006 02:02 AM
