Gutted my pipe today
Old May 6, 2012 | 10:22 PM
stevereno's Avatar
stevereno
Thanks for post DUC. Just did mine the same way, but with a bit longer cut which actually ended up about a 1/2" on both sides of the cat material. Made it easy to clean out the heavy, but need to get the remaining off the walls of the pipe... How did you get yours that clean? A heavy wire wheel maybe?
Old May 6, 2012 | 10:51 PM
Duc's Avatar
Duc
I used Dremel heavy duty cutting disk and a stone bit then the wire wheel attachment to clean up/smooth. Easier than a big wire wheel to work the odd shaped surface.
I tell you the sound difference is great, no plans to buy slip-ons.
Clif
Old May 6, 2012 | 11:01 PM
lh4x4's Avatar
lh4x4
I'm super cheap so a cut out a smaller window dug it out and used some scrap sheet metal I had laying around, shaped it, used a 1/2" wide JB Weld bead and secured the piece on with 7 SS hose clamps (one was on the heat shield). Works great!
The tone is a little deeper but the total sound is not a decibel higher. Third bike that I have done with the same results. The stock mufflers are rated at 80 dbl and they hold the exhaust volume to that if there is a cat or not. That is what they are engineered to do.
I have put 18K on the 10 Ultra and the system has held together. Gotta love JB Weld.
Old May 7, 2012 | 06:12 AM
RK Joy's Avatar
RK Joy
Interesting! I would not have expected that much difference. I can't imagine trying to do something like that myself. no welding equipment!
Old May 7, 2012 | 10:57 AM
Duc's Avatar
Duc
I almost did the exact thing, figured it would be easier and would be a future insp point if I ever wanted to crack back open.
Clif
fourburgs
Milwaukee Eight (M8)
11
Feb 26, 2017 09:09 PM
p51bombay
Sep 23, 2014 09:57 AM
cyclescoot
Dec 8, 2012 10:43 AM
Northbound Southerner
Apr 21, 2011 07:54 PM
iwant1
Harley Davidson Videos
Jul 7, 2006 10:04 PM
