Primary Fluid
Old Apr 24, 2012 | 09:44 AM
HD Jim's Avatar
HD Jim
2007 FLHX... I use Redline products in all 3 holes ...
Old Apr 24, 2012 | 09:49 AM
Shredding rubber's Avatar
Shredding rubber
Rotella Dino 15w-40. You can run any oil that carries the JASO M2 stamp. That spec means it's wet clutch safe. All the rotella lines of oil are JASO rated,as are the very expensive v-twin oils. Considering it's application I find no reason to put a high dollar lubricant in the primary when an inexpensive one will do. Save the expensive stuff for the engine
Old Apr 24, 2012 | 01:44 PM
TUCCI's Avatar
TUCCI
Agreed....Rotella goes in my primary as well, if it can handle a diesel engine its good to go in my primary.
Old Apr 24, 2012 | 01:59 PM
albngore's Avatar
albngore
Redline MTL in primary. Redline Heavy Shockproof in transmission. Mobil 1 V-Twin in engine.
Old Apr 24, 2012 | 02:59 PM
Galdog's Avatar
Galdog
Rotella 15-40 in the primary..... seems to work the best in my bike and I've tried numerous oils in it.... Amsoil in the other two holes....
Old Apr 24, 2012 | 05:17 PM
racklefratz's Avatar
racklefratz
Originally Posted by 37sportster
Hi all, i just read on here the other day that some people are using gear lube in their primay. I've heard of this in the tranny, but not the primary. Any thoughts on this? What are you guys running?
Nope - gear lube for the gear box, motor oil du jour in the other two holes.
Old Apr 24, 2012 | 05:34 PM
Jeffs386's Avatar
Jeffs386
Amsoil 20/50 in the engine
Spectro Platinum 6 spd in the tranny
Redline synthetic in primary
so far this is the best combo I have found for lower engine temp and smooth shifting
Old Apr 24, 2012 | 06:49 PM
FL-kruzen's Avatar
FL-kruzen
Originally Posted by Rickr01
I run Amsoil 20/50 in the Motor, Amsoil 75/140 in the Tranny and Harley Formula Plus in the Tranny! Bike is nice and quiet and runs perfectly with this combo.
+1 with Rick. I used the same mixture for my ride and all is smooth.
Old Apr 25, 2012 | 12:20 PM
mike_oh's Avatar
mike_oh
I am using Redline 20-60 in the engine, Mobil 1 70/140 in the tranny and B&M Trick Shift in the primary.
big- mike
May 3, 2017 04:35 AM
Brettfullthrottle
Jul 24, 2013 02:20 PM
EXAMMO
Oil Archive (no new posts)
Jun 20, 2010 02:22 AM
jose409
Aug 15, 2007 02:22 PM
Whiffleboy
Jan 22, 2007 07:46 PM
