T-Mann torqster cam ?
Old Apr 28, 2012 | 07:25 PM
Born2cure's Avatar
Born2cure
Default T-Mann torqster cam ?
Talked to dragos bike works today. He likes the t-Mann 555 torqster cams said he's getting good numbers. Presently I'm about to put in Andrews 54 cams. Anyone familer with these cams.
Thanks
Old Apr 28, 2012 | 08:14 PM
Fire-Medic's Avatar
Fire-Medic
James will be along shortly, he's running them in his 103, with heads, ported throttle body, and a Dragula, and got crazy results..........
Before I traded in on my CVO I was about to use the same cams (T-Man) for my 103....
I do not think you would be upset if you picked them. Not taking nothing away from the Andrews either, but I would just suggest to pick the one that better suits your riding style....
Old Apr 28, 2012 | 08:19 PM
DTTJGlide's Avatar
DTTJGlide
What's wrong with your Woods TW7h cams? The specs aren't that much different than the ones you're looking to switch to.
Old Apr 28, 2012 | 09:17 PM
cmcsns's Avatar
cmcsns
From: Beverly Hills, Fl. Swimmin pools. Movie stars
+1 on the Wood TW7H; been running it for about 15k miles and like although it does fall off sooner than I expected, but that's not really a bad thing for me
Old Apr 28, 2012 | 09:21 PM
Troy L's Avatar
Troy L
i just put a set of t-Mann 555 torqster cams in my buddys 2011 streetglide , it made 99hp and 112 tq with true duals and a marginal air cleaner.... i was pretty impressed....
Old Apr 28, 2012 | 11:51 PM
bklynbob's Avatar
bklynbob
Default much underrated cam.
the torqsters will come on earlier than the woods,and respond better to lower compression.
Old Apr 29, 2012 | 12:03 AM
Born2cure's Avatar
Born2cure
The woods are excellent cams but seems to come on little later seems 2800 rpms and drops off early. Also loud. Good numbers 108 tq and 96 hp. With true duels. Changing pipes to 2:1 fat cats so figure change out cams. Have the Andrews 54s but after talking to dragos (was impressed with knowledge and professionalism) I'm thinking going with their suggestion except I have the d&d in garage. I asked when he can get me in he said you won't be happy not till week of the 7th thinking June he said may. I was very pleased. I just wish I knew more about the pipes before I bought the d&ds.
Old Apr 29, 2012 | 08:08 AM
Born2cure's Avatar
Born2cure
Just but more info my compressions are 200 rear and 210 front. Figuring 10.5:1.
Old Apr 29, 2012 | 09:41 AM
bklynbob's Avatar
bklynbob
You might want to look into some headwork or a better tune,or both.If you don't mind the work involved,get a 31 tooth pulley also,don't change out the cams........
Old Apr 29, 2012 | 04:16 PM
2d3k2h's Avatar
2d3k2h
I have an 06 SG and run S&S 97" kit with T-Man 625 cam,his headwork,comp releases @ 10/5/1....put togeather at Lynchburg harley ....dyno at 105/109.Comes on @ 2400 and will carry to 5000.....I'd like it to come on earlier but am liking the power.Still get 40++++ mpg at 65/70
blackjeep
Engine Mechanical Topics
38
Aug 9, 2020 07:10 AM
Jondalar
Blowers/Turbos/Nitrous Oxide
Dec 15, 2014 04:45 PM
pat1
Sep 10, 2012 10:19 AM
Holzarbeiter
Dec 6, 2011 11:52 AM
snip0721
Exhaust System Topics
Jan 11, 2008 09:38 PM
