Why use pushrods?
Old Apr 29, 2012 | 06:17 AM
Silver Ghost's Avatar
Silver Ghost
Originally Posted by RIPSAW
One runs water thru what looks like a pushrod tube. Bet you cannot guess who that is?
Actually no. I can't, but I do see many Harley clones around here, but I really get kick out of the metric clone riders with there Harley jackets.
Old Apr 29, 2012 | 06:41 AM
RBWIDE's Avatar
RBWIDE
I mostly see 'em wearing the Harley half-helmets, especially on the Japanese 'cruiser' style bikes, but you're right. Cracks me up!
Old Apr 29, 2012 | 06:46 AM
RollaMo's Avatar
RollaMo
Originally Posted by senna
Corvette still uses pushrods, they perform pretty well. I like the fact HD uses pushrods, reminds me more of a hot rod.
Not just the Corvette, but all Chevrolet V8 engines.
Camaro, Corvette, SUV's, and pickups.
The C4 ZR-1 (1990-1995) used a double overhead cam engine (LT5).
The pushrod engines are just a simpler less expensive engine, fully capable of high performance.
NASCAR is still using pushrod engines, and they put out plenty of HP.
Old Apr 29, 2012 | 07:27 AM
iceman5218's Avatar
iceman5218
Thanks for the input guys. I'm not against the pushrods and after all the research I've done about doing a cam swap, I'm glad I don't have to pull the tank and take the top end apart to do it. Didn't know about the Chevy engines still using pushrods.
After some of the dyno sheets I've seen it's obvious these engines will still produce, just curious why things are done the way they are done.
Old Apr 29, 2012 | 08:09 AM
timbo141's Avatar
timbo141
Originally Posted by Oldman Harley
You wouldn't have the Harley sound if you used overhead cams. It's all about the sound of the 45* V Twin.
Tim
Agree, and the one crank pin!
Old Apr 29, 2012 | 08:18 AM
harleyphoenix's Avatar
harleyphoenix
Ever hear a V-rod idle? Doesn't sound like a Harley.
Old Apr 29, 2012 | 08:23 AM
Scratt's Avatar
Scratt
Not sure if this is the motor I saw in a magazine, that guy had the whole bike put together and it ran, but if it came to this I'd rather have push rods.
http://108.163.194.210/~dbbpcom/dbbp...smo/desmo.html
Old Apr 29, 2012 | 08:36 AM
shortride's Avatar
shortride
I have often wondered why someone has come up with a well-timed electronic solenoid to operate the valves. It would take the mechanical load off of the engine. The only potential draw-back would be that electronic solenoid would draw a lot of amps to open and close the valves.
Old Apr 29, 2012 | 09:13 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
This sound is not the push rods. This is actually caused by the 315° later, then there is a 405° gap until the first cylinder fires again since the Harley motor shares a common crank pin. You would think they would be top and bottom and would be if the motor was flat but by having the 45 degree make one lag the other. Most later FI bike idle above 1000 rpm and it's really hard to even here it. This actually is shared by others. However most metrics have clam shell bearings on 180 seperate pins with a balance lobe between them to help with balance and smoothness. Harley started out as a washing machine engine design 180 index before electricity and spaced it at 45 to fit in the bycycle frame!? HA? most of the above it true however....When the first FI system came out you had to idle it fast enough so system to maintain a reliable idle. My 04 is slow to the point it hunts at least 75-100 rpm and idle below 1000 would not be reliable. Bet the really new system could be idled down to give the potato po sound of yesterday. Remember the oil jests do not work at idle and only come in at 12-15lbs of oil pressure above idle so as not to over-oil they cylinders at idle (at speed the oil is a coolant since the engine has pleanty of lubrication) This kind of engineering would have to be modified slight to get a potato po idle with out causing other problems.
Solinoid valves and a Harley V twin at 19,000 rpm. Wonder what that would sound like? Maybe wet French fries in hot oil.
Old Apr 29, 2012 | 09:18 AM
senna's Avatar
senna
Formula 1 engines use a inert gas operated solinoid to operate the valves, springs are only practical to a certain point, somewhere around 12,000-14,000 rpm. The F1 engine is running around 19,000 rpm. But it is not practical for a long life engine.
