Speedo question?
Old Apr 30, 2012 | 06:14 PM
fastalkintn's Avatar
fastalkintn
Default Speedo question?
I'm on a trip in the smokies and my speedo started bouncing today. Everything else is working/running fine. I replaced the speed sensor about 3 years ago. Any ideas what it could be? I feel like my transmission might have got a little hot today, could smell gear oil after a while in the mountains but no signs of leaks and the fluid level is good.
Old Apr 30, 2012 | 06:28 PM
fastalkintn
Should have added its a 2000 road king 95" with 42000 miles.
Old Apr 30, 2012 | 06:52 PM
mkguitar's Avatar
mkguitar
see if the sensor needs cleaning, they are magnetic and can pick up pieces of steel.
Mike
Old Apr 30, 2012 | 07:21 PM
oasis03's Avatar
oasis03
Check your voltage with the bike running. My voltage regulator went bad and my speedometer went nuts.
Old Apr 30, 2012 | 08:44 PM
fastalkintn
So when yours went bad did you have any other symptoms?
Old Apr 30, 2012 | 08:58 PM
oasis03's Avatar
oasis03
The only thing on my bike that was not working as it should was the speedometer, the odometer seam to still be working. I checked the speed sensor and it was clean and checked out ok. I stumbled on to the voltage regulator by accident . Hope this helps.
Old May 3, 2012 | 02:31 PM
fastalkintn
Thanks to everyone for their help. After some testing I have concluded that it was the sensor going bad and have one on order to replace it.
RosevilleRiding
Jun 2, 2018 08:47 PM
1999evo
EVO
Sep 15, 2015 01:58 PM
quickster
Electrical/Lighting/Alarm
22
Aug 10, 2014 08:25 PM
Straight_To_Hell
Jun 15, 2014 01:49 PM
buddyman47
Oct 9, 2013 07:09 PM
