removing ON/Off switch
Old May 1, 2012 | 06:20 PM
catcher's Avatar
catcher
Default removing ON/Off switch
04 Road Glide. Trying to get lower plastic cover off under speedo so I can tighten handle bars. Have the top half off but must remove on/off/lock handle in order to get cover off far enough to get to handlebar allen bolts. How do you remove the chrome switch handle that has the locking mechanism in it?
Handle bars keep moving and I really need to tighten them. Thanks, in advance. BA
Old May 1, 2012 | 06:40 PM
wtb3886's Avatar
wtb3886
see if this helps
https://www.hdforums.com/forum/touri...ep-w-pics.html
Old May 1, 2012 | 06:41 PM
Airborne350G's Avatar
Airborne350G
http://www.youtube.com/watch?v=7-QBH...e_gdata_player
Old May 1, 2012 | 06:42 PM
mkguitar's Avatar
mkguitar
whatever you do, make the tool- do not use a screwdriver or you'll be posting asking "what went wrong"
mike
Old May 1, 2012 | 06:48 PM
CC Rainman's Avatar
CC Rainman
mike
I have been using a Craftsman with no problema at all.
Old May 1, 2012 | 07:56 PM
catcher's Avatar
catcher
Default removing on/off
Thanks guys, All I need, appreciate your help.
Old May 1, 2012 | 10:44 PM
Harleypingman's Avatar
Harleypingman
Originally Posted by wtb3886
Originally Posted by Airborne350G
It's great to see folks try to help; but, providing wrong information may not be helpful.
The OP posted re '04 RG; the posts above deal with '06 and newer bikes which have a different lock and different procedure for removal.
Suggestion: Just because something works on '06 and newer models doesn't mean it will work on an '05 or older model.
Carl
Old May 2, 2012 | 10:09 AM
Airborne350G
Carl,
is this the steps for a 2005 and earlier model?
1. Turn the ignition KEY to unlock and leave the key inserted in lock assembly
2. Move ignition assembly to the "Off" position to unlock the forks. LEAVE THE KEY IN LOCK
3. Turn the Handlebars all the way to the right
4. With the ignition key still in the lock turn the LOCK ASSEMBLY to "Access"
5. Standing on the left side of the bike look at the lower left underside of the LOCK ASSEMBLY. You will see a small button in the rear left corner
6. Use a small screwdriver to depress the button and hold while pushing down on the KEY (the *KEY* not the entire ****) and turning it 60 degrees in the counter clockwise direction.
7. Lift and remove ****
8. Reverse to reinstall except there is no need to depress the button
A good day is when you learn something new.....
Old May 2, 2012 | 11:15 AM
Harleypingman
2. To remove the ignition switch ****, insert the Ignition
Switch key and turn to the UNLOCK position. Leaving
the key installed, rotate the **** to ACCESS. Depressing
the release button at bottom (left side) with a small
screwdriver, push key down and turn an additional 60
degrees in a counter-clockwise direction. Lift and
remove ****.
The above is from the '05 HD Service Manual. The same procedure works on the '04 EG that I have.
It's slightly different from what was posted previously by Airborne350G (e.g. no mention of turning the forks to the right--that's not required but if the bike is on the kickstand, doing so makes it a bit easier to access the release button that needs to be depressed.)
Carl
Old May 2, 2012 | 01:16 PM
CC Rainman's Avatar
CC Rainman
Carl
Your right Carl, my mistake I did not read the post correctly. Probably due to lack of sleep.
lhgdale
2014-2024 Touring Models
Dec 1, 2014 06:11 AM
big kal
13
Aug 17, 2014 08:03 AM
jfanton
Feb 21, 2010 01:57 PM
spyman
Jun 3, 2007 11:55 PM
hogsolo16
Jun 21, 2005 12:59 AM
