Head Bearing - Swing Test... HELP NEEDED
Old May 6, 2012 | 06:51 PM
jasnusc's Avatar
jasnusc
Default Head Bearing - Swing Test... HELP NEEDED
Im adjusting my head bearing by doing the swing test and my front end does Not return to center.
No matter what I try it always stops turned to the right which is affecting my ability to judge the proper number of swings and is making me worried something is wrong.
Things I did to try to stop it from happening:
  • Removed Clutch Cable Completely From Bars & Fairing
  • Made Sure Bike Was Sitting Level On Lift
  • Made Sure Wire Harness Not Rubbing On Anything
  • Greased Neck Bearings
  • Removed GPS From Handle Bar To Make Sure It Wasnt Throwing Off The Weight
  • TBW Throttle No Cable To Remove
  • Brake Line Attached To Front End No Need To Remove
Any Other Ideas?
Old May 6, 2012 | 06:57 PM
dawg's Avatar
dawg
How many swings did you get (even with it going to the right)?
Old May 6, 2012 | 07:05 PM
jasnusc's Avatar
jasnusc
In one direction I got 3-4 swings just like the diagram in the manual. In the other direction I only get 2 swings and it stops off center.
Old May 6, 2012 | 07:06 PM
jasnusc's Avatar
jasnusc
This is on my 09 Street Glide by the way....
Old May 6, 2012 | 07:12 PM
dawg's Avatar
dawg
M1246
Old May 6, 2012 | 07:17 PM
jasnusc's Avatar
jasnusc
Originally Posted by dawg
Thats the same as my service manual and exactly what I did. The first page says its special for 2009 but I didnt see anything special? Where you trying to show me something specific that I missed?
Technically it doesnt say that it has to return to center it just says "it should At or After the straight forward position" which mine stops After and technically it says turn the bars to the left which is the way my bike works the best. When I turn it to the right it stops short.
I really appreciate you trying to help just wasnt sure if I missed something in the link you provided?
Old May 6, 2012 | 07:20 PM
dawg's Avatar
dawg
It doesn't necessarily have to stop at center, the amount of swings is the important part.
Old May 6, 2012 | 07:34 PM
jasnusc's Avatar
jasnusc
Cool Thanks!
Silvio
Apr 28, 2015 03:24 PM
skully1200
May 4, 2012 05:13 PM
All Aces
Aug 20, 2010 09:35 AM
commander112
Jun 21, 2010 09:36 AM
RazorFXDB
Aug 29, 2007 06:17 AM
