Engine cooling question after wind deflector install
Old May 12, 2012 | 06:05 PM
Fathertime500's Avatar
Fathertime500
Default Engine cooling question after wind deflector install
I'm worried about enough air flowing over engine to cool it. Just installed fork deflectors and fork baffle on my limited. Should I be concerned ? I did do a stage one with V&H power duals and power vision so no more cat. Any thoughts? FT
Old May 12, 2012 | 06:21 PM
rhlhamlet's Avatar
rhlhamlet
You probably should take the fork deflectors off in hot weather. I use them from November to March here in FL but would cook if I left them on when its hot.
Old May 12, 2012 | 06:50 PM
ColoSpgsMark's Avatar
ColoSpgsMark
I think you'll be fine. You can use your PV to monitor engine temps if you get concerned. If anything, baffle off first as the fork deflectors do a great job on their own of keep the buffeting down - at least on my bike.
Old May 12, 2012 | 07:17 PM
boom23's Avatar
boom23
Just keep an eye on the oil temp. If it gets too hot, start removing things that may affect air flow. I assume you're using synthetic oil and you have an oil cooler, which always help.
Old May 12, 2012 | 07:23 PM
rcmlndz's Avatar
rcmlndz
No problems so far. Have both fork mounted and the small one between the forks. Just came back from a ride 214 F. I run synthetic in all three holes and have oil cooler
Old May 12, 2012 | 09:04 PM
Fathertime500
Thanks for all the responses so far. I guess I need to buy an oil temp gauge and start monitoring myself. FT
Old May 12, 2012 | 10:02 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
worry no more, try these, they work great for me http://www.wardspartswerks.com/cooling-fans.html
Old May 12, 2012 | 10:08 PM
buell95's Avatar
buell95
I see Jims has a new cooling system out you might want to try it also.
Pale Horse Rider
Oct 6, 2014 06:59 PM
trackadaptor
Touring Parts
Jul 23, 2014 10:07 AM
watercop
Aug 6, 2011 12:10 AM
mhud
Dec 16, 2007 09:23 AM
rkc9999
May 18, 2007 02:04 PM
