Oil pan "Hex Plug"
Old Apr 6, 2019 | 07:00 AM
  #31
skinman13's Avatar
skinman13
That is where HD puts the sending unit for the oil temp indicator kit upgrade. One terminal oil temp senders typically used on automotive aftermarket gauges need to ground to the oil pan through the threads so using Teflon thread seal tape might not work. The HD sender has two terminals and is internally grounded. I "discovered" this when I installed a $30 automotive gauge and sender and It didn't work...Duh!. When I took off the tape, it worked but leaked without sealant. Since the gauge didn't match the HD gauges very well and was really messing with my OC, I replaced it with the $127 HD kit this time using pipe thread sealant. I am liking it so far...
Old Apr 6, 2019 | 09:18 AM
  #32
multihdrdr's Avatar
multihdrdr
Use Electrically Conductive Thread Sealant
Old May 15, 2019 | 02:36 PM
  #33
Jbpooh's Avatar
Jbpooh
I'm looking at doing this to my Ultra. Do you remember what the thread size was for the hex plug adapter? 1/8 ,1/4, or other?
Old May 15, 2019 | 05:29 PM
  #34
Spartanden's Avatar
Spartanden
Roguebear and Airborne... I was 13Bravo and I would have woke your *** up anytime during the night!!!
Gents.... thank you for your service. And welcome home!!!
Go Army!
Old May 16, 2019 | 11:11 AM
  #35
skinman13's Avatar
skinman13
The MoCo kit comes with the adapter and does not sell it separate from the kit. It is a brass 3/8 NPT external-1/8 NPT internal thread adapter, easy to find at Lowe's or Home Depot. It is pipe threads so you will have to use thread seal or it will probably leak. MoCo calls for Loctite 565 Thread Sealant...I used a Permatex equivalent
Old May 16, 2019 | 09:21 PM
  #36
Jbpooh's Avatar
Jbpooh
Ok thank you!
Old Feb 6, 2020 | 05:04 PM
  #37
carbonDRED's Avatar
carbonDRED
I know I'm resurrecting an old thread, but will I need to add any additional oil since I removed my "THOU SHALT NOT TOUCH THIS" plug by accident as well? Service manual calls for 4qts but do I do 4.5ish to refill the sump? 2010 RKC
Old Feb 7, 2020 | 08:59 AM
  #38
62hdbiker's Avatar
62hdbiker
Check your dip stick oil level. Oil should of come out the hole since that is where the optional temp gage goes and needs to be in the oil. I used that hole to supply oil to my S&S motor per their instructions- so I know there is oil above that hole
Old Feb 7, 2020 | 09:03 AM
  #39
carbonDRED's Avatar
carbonDRED
Yep it did. Oils completely drained. I got an extra quart just in case the 4 the service manual calls for isn’t enough but I’ll check the stick. Do I need to run it a bit to circulate it through the sump?
Old Feb 7, 2020 | 09:37 AM
  #40
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Put the same amount you have been using for an oil change, then take it for a ride.
Check after and adjust if needed.
