Exhaust stud flange nut size? Anyone?
To replace that 5/16 x 24 nut that fell off
I removed the right saddlebag to loosen the rear mount on the D & D FatCat pipe.
Loosened the middle mount on pipe.
Removed the front heat shield after removing the right foot board, clipped a couple cable ties to get at floor board hardware.
Clipped a cable tie and moved the clutch cable out of the way so I could get at the studs.
Put the new nut on and re torqued both nuts.
Put all that chit back on. Tightened a couple of loose bolts that I didn't know about.
Only looked at my notes in owners manual a couple of times.
Job done, now it's Miller Time.
