Ethanol Sucks...Recommendations?
Old May 18, 2012 | 08:34 PM
North Star's Avatar
North Star
Originally Posted by hdsuspension.com
In Canada you cannot but ethanol free anywhere that I know of. I simply buy STP fuel additive which increases my octane level - Noticeable let me tell you! No knock or ping when added. Ethanol I believe is here to stay...
Not true- Shell 91 is ethanol free.
Old May 18, 2012 | 09:07 PM
mgmmgm's Avatar
mgmmgm
Thumbs up Sta-Bil Marine
Originally Posted by mike5511
I use the Sta-Bil marine formula, so far so good. (lucky enough to use mostly real gas most of the time also)
+1 on the marine grade Sta-Bil
Noticed the local HD stealer was selling it at service counter.
Paid $4.39 gal for non- corn 92 octane today, filled 'er up. Also, put a K&N air filter on replacing the stock ventilator air filter.
Noticed better running and the computer said I could go 270 miles = 45 mpg. Normally I get 41-43 mpg.
Old May 18, 2012 | 09:15 PM
lh4x4's Avatar
lh4x4
Keep voting in those whacked out politicians every time. You get what you pay(vote) for.
Old May 19, 2012 | 05:59 AM
ddm502001's Avatar
ddm502001
If you crunch the numbers, when we burn ethanol we still burn the same quantity of just the gas for the same miles as without. I lose 10% mileage with a 10% ethanol, that means I still used the same amount of straight gas regardless the BS alcohol added for the miles driven.
Time to set the politicos down and force them to do the math as well.
Old May 19, 2012 | 07:10 AM
mainboom150's Avatar
mainboom150
use shell gas and seafoam or lucas fuel additive but i would say biggest one would be shell gas
Old May 19, 2012 | 06:24 PM
Timekeeper10's Avatar
Timekeeper10
Originally Posted by bigskyroadglide
go to pure-gas.org. It is a nationwide listing of all stations in the US that sell ethanol free gas. it is sortable by state
I checked pure gas .org for Topeka and it was wrong. I am not sure it is accurate.
Old May 19, 2012 | 08:16 PM
mgmmgm's Avatar
mgmmgm
Anyone use Lucas fuel treatment?
Old May 19, 2012 | 08:27 PM
gonzo3426's Avatar
gonzo3426
my $0.02:
- it's all propaganda...someone's makin a lot of money on this ethanol stuff;
- ride often so the gas doesn't sit long;
- if you're not going to ride and will let it sit, it would be best to just drain tank instead of spending more money on additives, etc.
Old May 19, 2012 | 08:42 PM
cdestuck's Avatar
cdestuck
Originally Posted by Lowcountry Joe
You always have the option to fill up at a local airport with av-gas. It's expensive, and has lots of octane, but no ethanol. I know a guy that does that with his old Triumph. Says the bike feels like it has a third cylinder with that fuel.
I buy Av gas for my two cycle equipment to get away from ethanol. But last week was talking to a guy who seemed a bit smart on the stuff. He claims av gas is slower burning that reg gas as aviation engines run at a fairly slow rpm level. He believes that it still burning as the exh valves are opening so you loose some of the power and if this is true,I'm wondering if this is hard on the exh valves.
Chime in anyone.
Old May 20, 2012 | 07:18 AM
smithbrl's Avatar
smithbrl
Chime in anyone.
In the mid 70s avgas was 100 octane minimum. There was also an even higher grade. It will definitely burn slower but I don't know how it would affect/effect the valves.
