Smart Alarm
Old May 17, 2012 | 09:35 PM
bigcletus's Avatar
bigcletus
Default Smart Alarm
Today I was planning on taking the bike for my first ride this year. I put the FOB in my pocket, got on the bike, turned the ignition to "on", however all that happened was the alarm went off. Thinking the FOB battery was dead, I tested it and its almost at 100% power. The bike was on a tender since last fall and has lots of voltage. Any ideas what the issue is ??
07 RG
Thanks
Old May 17, 2012 | 09:43 PM
zoozoo's Avatar
zoozoo
Check kill switch.
Old May 17, 2012 | 09:44 PM
davessworks's Avatar
davessworks
Originally Posted by zoozoo
Check kill switch.
Nah! Surely not . . . LOL
Old May 17, 2012 | 09:46 PM
Frogprince's Avatar
Frogprince
By chance it isnt the style with the button? I cant remember the year when they switched over to the automatic style fob.
Old May 17, 2012 | 09:54 PM
zoozoo's Avatar
zoozoo
It happen to me once. (brain fart)
Old May 17, 2012 | 09:57 PM
davessworks
Is that you in your avatar?
Old May 17, 2012 | 10:32 PM
FtpdMoose's Avatar
FtpdMoose
Have had this happen to me a few times...not sure of the problem either...Subscribed!
Old May 18, 2012 | 07:37 AM
skratch's Avatar
skratch
its possible that there is something that is interfering with the signal between the tssm and the fob. easy to check. first, make sure that the fob is not in the same pocket as your cellphone. go to start the bike, if it does not start, then use your security override code (you did set one, right?) to start the bike. go for a ride. stop somewhere, and see if it does it again. if it does, then use your override code again, make another stop, try again. if it fails again, then you definitely have some type of problem with your security and will have to troubleshoot further.
Old May 18, 2012 | 07:57 AM
casique's Avatar
casique
You did say the FOB battery was good right? Replace it anyway...
Old May 18, 2012 | 08:01 AM
jeffreydsilver's Avatar
jeffreydsilver
Good preventive maintenance! REPLACE ALL DO HICKY BATTERIES YEARLY! Key FOB, alarm pager, etc.
