ultra classic edition switch
Old May 19, 2012 | 03:19 AM
patsas's Avatar
patsas
Stage I
Default ultra classic edition switch
in the run position the green neutral light doesn't come on thus motor won't start
Old May 19, 2012 | 03:26 AM
mkguitar's Avatar
mkguitar
pull in the clutch lever.
a harley transmission is designed so that neutral is more easily found from 1st gear, not 2nd.
If you think the switch is busted, it is on top of the tranny, easy to access and test ...... the other sensor is for the speedo, it has an offset fastener.
mike
Old May 19, 2012 | 05:53 AM
1st 96 ultra's Avatar
1st 96 ultra
if the trans switch is bad it should start by pulling in the clutch just like normal , if it don't keep looking . by the way is your kill switch on or off
Old May 19, 2012 | 09:28 AM
DrPlastic's Avatar
DrPlastic
Unless the Clutch lever was removed and the safety switch is busted!
Old May 21, 2012 | 10:23 AM
fordhd2005's Avatar
fordhd2005
That switch is just for the neutral indicator light if I remember correctly. I had an 01 RK that a few times it jumped when I hit the start button with it in gear. You got some other issue going on regardless, that's probably battery related.
Max Headflow
Milwaukee Eight (M8)
38
Nov 10, 2020 08:17 AM
tn_popo
Apr 11, 2019 06:13 PM
fffffish
Apr 14, 2016 05:27 AM
mswing1234
Jan 18, 2016 05:05 PM
clarkchriston
May 3, 2013 08:23 PM
