Fender drill for 21" wheel
Old May 20, 2012 | 09:34 PM
HOGNIT's Avatar
HOGNIT
Default Fender drill for 21" wheel
What's the best way to drill fender so paint doesn't chip to install 21" wheel? Kinda leery about drillin on painted areas
Old May 20, 2012 | 09:55 PM
CLL375's Avatar
CLL375
I just elongated the rear mounting holes. Nothing chipped.
Old May 20, 2012 | 11:09 PM
Larry the Landlord's Avatar
Larry the Landlord
Use masking tape and a punch to start the hole.
Old May 21, 2012 | 12:15 AM
mkguitar's Avatar
mkguitar
before you do.
lay the fender on the tire with an appropriate spacer, such as 3/8" fuel line taped on top of the tire ( like you see on the build off tv shows)
now eyeball it.
are you happy with the look ?
does the arc of the fender match the arc of the tire, wheels and rotor- or does the fender look squashed- and if so ,do you care.
if so you may want to look at getting a new fender and hitting the catalogs. ( or the popular fatboy fender or HD street stalker fender, which mount with adapter blocks.
if all is good, you can mark the positions for your new holes.
use brand new drill bits
pad and secure the fender so it can't spin if the drill bit grabs ( or get a Pal).
tape over the location with masking tape.
drill through quickly, do not let heat build up-
you choice is try a small bit and then go bigger- I prefer using a big bit and doing it once, making sure that I am centered on the mark
mike
Old May 21, 2012 | 12:46 AM
PistonPuller's Avatar
PistonPuller
Is this for a stock fender? Are you sure you need to elongate the holes? I had my 21 with stock fender and didnt need to do it. Now if you do, your only talking about moving the rear of the fender up a very slight amount. Like mentioned earlier you only need to elongate the hole. Use a bit that is slightly bigger than the hole that is already there. No need to drill a brand new hole.
Old May 21, 2012 | 06:06 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Our Tech likes to use a dremel tool to elongate the existing hole. He finds that the safest approach to prevent damage to the fender. Or tape around the hole and use a 3/8" drill bit to hog out the hole.
Old May 21, 2012 | 09:55 PM
BenRK05's Avatar
BenRK05
If your worried about clearance. A lot of people don't have any clearance issues. I didn't at all.
AGAF
Jan 12, 2018 09:44 AM
Ozark Joe
EVO
15
Nov 22, 2016 12:26 PM
Hogpro
Sep 20, 2012 12:02 PM
tbone22
Apr 18, 2009 09:56 AM
mopar7
Nov 24, 2007 06:48 PM
