New oil temp gage
Old May 21, 2012 | 02:07 PM
frenchbiker's Avatar
frenchbiker
Originally Posted by dparker747
I just installed one two weeks ago, the instructions said to use the air temp harness at the gauge end. The sensor wire connects to the 107 connector (air temp sensor). You unplug the air temp sensor and plug in the wire from the oil temp sensor. The trick was to find the 107 connector. On my Road Glide, it was burried inside the speedo/tac housing.
You're absolutely right, I mounted mine in 2010 and forgot about that. My bad.
http://www.harley-davidson.com/en_US...ts/-J04790.pdf
Old Nov 20, 2012 | 03:36 PM
Booggerbe17's Avatar
Booggerbe17
6th Gear
Default silver face gauge
Ok where can i get the brushed aluminum silver face oil temp gauge. The one that goes with the screamin eagle gauges. HD does not offer the gauge anymore. Thanks Booggerbe
Old Nov 20, 2012 | 04:35 PM
snailhouse_projects's Avatar
snailhouse_projects
i like the fact that the oil guages can be near eachother, i know that i would like to look in one location and see the temp and the pressure. on my softail i have the pressure guage sitting just above the points cover and it can be a pain in the **** to reach around to check pressure while riding.
Old Dec 6, 2013 | 12:50 PM
trbo2nr's Avatar
trbo2nr
Stage II
I just replaced my speakers with the upgraded Boom type. Now that I have the oil temp gauge in-place, I am about to go on a hunt for the 107 connector. If and when I locate, I will snapshot a picture of it.
Bob
Old Feb 18, 2014 | 09:06 PM
BornTexan's Avatar
BornTexan
Originally Posted by frenchbiker
This part number is for the SG oil temp gauge with the silver face. The black face gauge is part# 75265-04A and it comes with a (metal) bracket. I didn't use the bracket. I used the plastic one from the useless air temp gauge and I relocated the voltmeter where the air temp gauge was so that the 2 oil gauges are together on the right side.
Did the same thing, chunked that worthless air temp (or just how hot is it in my fairing) gauge and out the volt gauge there. Put the oil temp gauge in its place on the right side. Other than having to pig-tail the harness to each gauge it was a fairly simple job.
o~\o
Old May 14, 2014 | 03:53 PM
UltraClassicElectraGlide's Avatar
I know, old thread, but for anyone here that has installed the silver face oil temperature gauge, I seem to remember some sort of issue with either the fitment into the panel or some other sort of inconstancy compared with the other factory silver face gauges. I was thinking maybe something about the color of the gauge at night, but wouldn't I use the existing light bulb from the ambient air gauge? I can't remember what the issue or concern was... it's a drag to get old.
At some point I'm going to install the silver face gauges I already bought and thought I would add the oil gauge at the same time. I know some people take issue of the point of the oil temperature gauge but I think it's still better than the silly ambient air temperature gauge.
Once installed, does is look exactly like the original OEM silver face gauges?
Old May 14, 2014 | 04:07 PM
2TallGlider's Avatar
2TallGlider
Bob
The 107 connector for my '09 Ultra was located on the left side of the steering head tucked in amongst the wiring harnesses. On the steering head you will see a small black box mounted with a cable attached to it...that is the 107 connector (if I remember correctly). Just unplug the cable from the black box. I hope this helps.
Old May 14, 2014 | 04:35 PM
Keithhu's Avatar
Keithhu
Bob
You have a Road Glide. I just did this. Its inside the Speedo/Tach housing.
Old May 14, 2014 | 05:06 PM
dochawken's Avatar
dochawken
Originally Posted by shortleg
How do you use the connecter that goes at the gage end?
Do you reuse the old air temp connecter some how?
Thanks Shortleg[Dave]
Yes...plug and play...locate the air temp sensor, remove the cap and plug the oil temp sending unit to it.
Old Apr 8, 2017 | 12:49 PM
Sparkybob477's Avatar
Sparkybob477
2nd Gear
THANK YOU dparker747!!! Been looking for that connector for an hour now!!
Rickr01
Feb 3, 2014 02:29 PM
HDF Tech
Oil Archive (no new posts)
Apr 28, 2011 10:27 AM
johnica
Feb 7, 2009 11:50 AM
fxlowboy
Jul 12, 2008 08:58 AM
bskubon
Dec 27, 2005 09:57 AM
