Which jet?
Old May 31, 2012 | 11:11 AM
Need4Speed305's Avatar
Need4Speed305
5th Gear
Default Which jet?
Just put on some Rinehart True Duals on my '06 Street Glide and need to change out the jetting. Anyone know which size to use?
Old May 31, 2012 | 11:16 AM
Jinks's Avatar
Jinks
Take a look on the Rinehart installation instructions. It's in the same section as the sizing for the muffler bearings......
Old May 31, 2012 | 11:20 AM
mkguitar's Avatar
mkguitar
"muffler bearings" is a joke.
the jet required depends on other factors.
if you go to nightrider.com
in the bike tech section are tips for tuning and modifying the CV carb.
many go to a huge jet, but it really depends on the bike.
too large a jet will work, but poor MPG and soot will result.
my last carbed bagger ( 80") had a modded carb with a chamfered, polished slide and a drilled air bleed hole.
best results with the sportster needle were with a 42/170
mike
shvlrydr's Avatar
shvlrydr
I also have a carbbed 06 with rineharts and am currently running a 46 slow and a 190 main
Old May 31, 2012 | 11:34 AM
KCFLHRC's Avatar
KCFLHRC
Old May 31, 2012 | 01:47 PM
Need4Speed305
5th Gear
Are you using the stock carb? Do you find this a good combo?
Old May 31, 2012 | 03:13 PM
shvlrydr's Avatar
shvlrydr
yes, stock CV40 carb...runs a little rich but thats ok, better than lean IMO. But after looking in my box of jets the 190 is there so it must have a 185 in there now...
Old May 31, 2012 | 03:20 PM
stevefxdi's Avatar
stevefxdi
i have a 2006 roadking hi flow air cleaner tru dual head pipes and cycle shack slipons, running a 46 low jet a 190 main jet and my mixture screw turned out 2 1/2 turns, i get about 42 mpg if your looking for mileage
Old May 31, 2012 | 04:11 PM
Mick's Avatar
Mick
I had a good combo on my 06 FLHT.
With a Ness Big Sucker and V&H sraight cut classic slip ons and stock carb.
I went with the old Sportster needle # 27094-88 , stock main jet and a #48 pilot jet at 2 turns out.
You will have to unplug the mixture screw for slow speed also.
Originally I tried a #46 pilot , but it wasn't enough for my particular setup , but it might work for you.
The stock main will flow enough for almost any build , unless you get really wild.
I tried 190 , 195 , 200 , and the stock jet was the best for mine.
I also tried using #4 machine washers under the stock needle , but the sportster needle was a better mix.
You should be able to tune it pretty fine for around $20.00 if you are methodical and pay close attention to the sound of your engine and the fuel mileage.
My best mileage with this combo was just about 50 mpg , and I was riding with a very light throttle hand.
Mick
Old Jun 1, 2012 | 10:49 AM
Need4Speed305
5th Gear
OK, went to the dealer and they looked at me like I was nuts. Stock is 48/190. Any other suggestions?
