Adjusting handlebars on a Road Glide
Old May 31, 2012 | 11:53 AM
Afishinado's Avatar
Afishinado
Default Adjusting handlebars on a Road Glide
Need to adjust the handlebars on my new Road Glide back an inch or so. Can someone give me a link that has the procedure? I popped out the gauge cluster and can get to two easy enough, but the two on the rear side of the clamp are covered. So then I loosened the screws holding the covers on the side (on the front legs) but the plastic is fastened somewhere around the switch and I can't figure out how.
Thanks in advance
Old May 31, 2012 | 11:57 AM
Gearhead3's Avatar
Gearhead3
With the two rear bolts loosened, you still couldn't move them back?
Old May 31, 2012 | 12:16 PM
Afishinado's Avatar
Afishinado
Can't get to the two rear bolts (on the clamp), that's the problem. They're covered with the plastic bottom halves of the enclosure
Old May 31, 2012 | 12:24 PM
XARAN's Avatar
XARAN
There are 2 ways to do it . By the manual and the correct way is too remove the Ign Switch and then you can remove the lower plastic cover. The way a lot of people do it is to take a Dremel or file etc and cut away the plastic just over the 2 rear clamp bolts, the top cover will hide it as long as you only take off what you need to.
This is a good thread and video on switch removal
https://www.hdforums.com/forum/touri...ml#post9416189
Old May 31, 2012 | 12:26 PM
Gearhead3's Avatar
Gearhead3
My bad, I meant front bolts. I've never had to loosen the two rear bolts, it has always been enough to just loosen the two fronts.
Old May 31, 2012 | 02:20 PM
ctmedic's Avatar
ctmedic
Lossen (Don't Remove) the 2 bolts under the cluster cover and rotate your bars to the desired area. Then tighten them up. Remember you may need to also lossen your controls and move them as well.
Easy job, however make sure the bars are not to low that they hit the tank or that your rotaing them up to high that they contact the shield.
(Don't ask me how I know
Good luck
Frank
Old May 31, 2012 | 03:41 PM
larsfum's Avatar
larsfum
Old May 31, 2012 | 03:46 PM
vduzin12's Avatar
vduzin12
Good luck
Frank
I bet that was priceless!
Old May 31, 2012 | 04:52 PM
Afishinado's Avatar
Afishinado
I thought about trying just the front bolts on the clamp, but really don't like that idea much.
Old Jun 2, 2012 | 07:49 AM
Afishinado's Avatar
Afishinado
Thumbs up
Originally Posted by xaran
there are 2 ways to do it . By the manual and the correct way is too remove the ign switch and then you can remove the lower plastic cover. The way a lot of people do it is to take a dremel or file etc and cut away the plastic just over the 2 rear clamp bolts, the top cover will hide it as long as you only take off what you need to.
excellent thanks
ZenGlide
Apr 18, 2015 02:30 PM
big kal
13
Aug 17, 2014 08:03 AM
Catfish57
Jul 1, 2013 07:16 AM
catcher
May 2, 2012 01:16 PM
jfanton
Feb 21, 2010 01:57 PM
