New cams installed
Old Jun 19, 2012 | 10:28 PM
Bushrider's Avatar
Bushrider
Default Hmmmmm.....
I put in 255's, fatcat, SE ventillator, TTS dyno tune (9 hours). Result was 89 hp and 110 tq. I burn quite a bit more gas, some popping on decel (not a lot).
1500 rpm is pretty low; try to avoid lugging your motor.
I think you're right; you can do better. How long on the dyno?
Old Jun 20, 2012 | 12:05 AM
mgmmgm's Avatar
mgmmgm
I was thinking of having a dyno run done this week to see what #'s I am making.
Probably could do better on paper without the packing removed from the baffles.
Old Jun 20, 2012 | 12:27 PM
mtclassic's Avatar
mtclassic
What dyno in spokane?
Old Jun 20, 2012 | 12:34 PM
Keithhu's Avatar
Keithhu
Originally Posted by JDG1172
Ok... It has been a couple of weeks since I swapped my cams. I have been a slacker posting my results. TQ is 103.5@ 3713 rpm. Max HP is 90.6 and 73.16 @ 3713. I had it dyno tuned at HD dealer here in NH, I think there could be a little more low end added by adding a little more fuel. I'm no expert at tunning these things but at really low speed below 1500 rpm it pops and pretty much dies. Like in stop and go traffic. Also if it goes into one cylinder mode in traffic it revs up after hitting the throttle. Anyone have any advice about this problem?
My bike is 2009 RG with se intake, slip ons and stock head pipe.
Joel
I would not take my bike to a dealer for a tune, generally. I'm sure there are some good ones out there, but unless you're sure I'd go to someone with a good reputation
your 1 cylinder problem sounds like the EITMS system working as designed- heat management. Was it really hot out?
Old Jun 20, 2012 | 05:35 PM
jfarrar30's Avatar
jfarrar30
definetly sounds like it needs a bit more tuning. low end on mine (like letting out the clutch slow without alot of throttle like when menuvering the bike around) will just go. no popping or stalling. It doesnt have the greatest low end pwr but definetly hauls the mail. What aircleaner you running? Took me a while to get used to the knocking sound that comes out my intake is why I ask. Jamie says its valve overlap and my ac amplifies it more than others.
evhid1
Engine Mechanical Topics
14
Jul 22, 2017 06:27 PM
Daredevil
Mar 29, 2017 01:11 PM
stal94gt
14
May 20, 2016 01:45 PM
Stl.glider
Jan 4, 2013 08:45 AM
cruzmisl
Aug 6, 2011 01:01 AM
