Wheels Installation Quote
Old Jun 5, 2012 | 01:11 PM
Cornel's Avatar
Cornel
Default Wheels Installation Quote
After a long back-order waiting period I finally received my Agitator wheels. I also purchased new tires and wheel installation kits.
My dealer quoted me 3 hours of labor. At $110 per hour that is not chump change.
Does 3 hours seem about right to press in new bearings mount the tires on the wheels, remove old wheels and install new wheels?
Thanks!
Old Jun 5, 2012 | 01:24 PM
Nicky Pass's Avatar
Nicky Pass
My dealer said its 2-3 hours including pressing in the bearings....but when I put my Agitators on 2 weeks ago, my dealer had a deal.....if you buy the tires there, they don't charge for the install. I had to pay for the bearing to be pressed though....like $80.
Old Jun 5, 2012 | 01:29 PM
dbell66253's Avatar
dbell66253
Seems a bit high, but dealers aren't cheap, I'd go to an indy, you'll probably pay about half.
Old Jun 5, 2012 | 01:34 PM
Shakeydeal's Avatar
Shakeydeal
My indy charges 60.00/hr on all labor.
Shakey
Old Jun 5, 2012 | 02:00 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
Shakey
Lynchburg, va vs northern cali? you think theres a difference there? locations dictate labor costs you can't compare one to the other unless you're in the same neck of the woods
Old Jun 5, 2012 | 02:56 PM
Cornel's Avatar
Cornel
I don't have any vetted and recommended independent shops in my area. The dealer where I am taking it (McGuire H-D in Walnut Creek) does very good work, I am just curious if it really takes 3 hours for the work to be performed.
Old Jun 5, 2012 | 03:55 PM
sortasuave's Avatar
sortasuave
3 hours is about what I had quoted to me for the same work.
Given that you have already purchased the tires, I would go with an indy to get the work done. If at all possible you might even install the tires yourself after the bearings and wheels have been mounted. That's what I did and it saved me a good chunk of $$...
Old Jun 5, 2012 | 04:30 PM
Texas Fat Boy's Avatar
Texas Fat Boy
The "labor time" seems about right....and I think that was your question.
Old Jun 5, 2012 | 04:50 PM
chopper king matt's Avatar
chopper king matt
wow im in the wrong country if there charging that much an hr for labour lol
i do all my own work inc fitting so sorry cant help you with that but it seems a lot from this side of the pond
Old Jun 5, 2012 | 05:07 PM
jsims002's Avatar
jsims002
Surely folks you ride with are handy with a wrench. Trust me, I'm Nooooo mechanic, just a hobbiest and I put the bearings in my wife's Black Ice muscle wheels and my FLHTP Agitator front wheel (both bikes have ABS), had a local guy mounted the tires for $20. I added 3oz of dyna beads myself in all the tires, put the rotors on. So, that cost me $20. If you have a 35mm socket, you can use it to tap the bearings in. DON'T YOU DARE LET SOMEONE CHARGE YOU $300 for 45 minutes of actual work.
