Cam Bearings
Old Jun 13, 2012 | 03:47 PM
00RKVT's Avatar
00RKVT
Default Cam Bearings
I have a 2000RK. The cam bearings went on it. i need to know what is the best bearing that money can buy so i can fix this problem. I need brand name and a bearing number If you have it. Thanks
Old Jun 13, 2012 | 05:45 PM
Big Blue Bike II's Avatar
Big Blue Bike II
Inner bearings - in the case or outer bearings - in the cam plate or both?
Inner - Torrington B-148
Old Jun 13, 2012 | 07:46 PM
00RKVT's Avatar
00RKVT
I'm gonna replace both while I'm in there. torringtons are the best?
Old Jun 13, 2012 | 08:05 PM
dv102's Avatar
dv102
I just changed out all my cam bearings used the torringtons for the inner ones and the outer ones at HD. If you havn't changed the cam tensioner you might want to do that also while it is apart. They will cost you another $150 bucks for the tensioners.
Old Jun 13, 2012 | 08:34 PM
dawg's Avatar
dawg
If ya need any help, tow her on down to White River Jct and I'll give you a hand. Might as well do the hydraulic upgrade whilst you're in there.
Old Jun 13, 2012 | 08:40 PM
00RKVT's Avatar
00RKVT
Anybody have part numbers for the bearings? Thanks for all the replies. I will keep you in mind dawg!
Old Jun 13, 2012 | 08:48 PM
dv102's Avatar
dv102
I bout the inner torringtons from Georges Garage 15 bucks for both,I also bought the installation tool there also. I got the outer ones at HD part#8983 & 8990A.
Am4wag
Engine Mechanical Topics
Nov 3, 2014 05:52 AM
cocheese72
Jan 24, 2013 05:48 PM
magnum629c
Jan 26, 2012 03:19 PM
rkoivisto
Nov 23, 2010 05:16 PM
cpotts454
Jun 11, 2010 04:12 PM
