How are miles on the odometer calculated?
Old Jun 17, 2012 | 08:12 AM
Keithhu's Avatar
Keithhu
Default How are miles on the odometer calculated?
I have a 2012 Road King, buddy has a 2005 Road King Police.
On a trip this weekend, when we filled up, we both zero'ed out Trip A.
Ride some more and fill up again.
My trip odometer would say something like 134 miles, his would say 130.
Only thing I can think of is that I've replaced my front wheel with a 17", while stock 2012 RK's are 16".
Is that the reason?
Old Jun 17, 2012 | 08:17 AM
rdc401's Avatar
rdc401
No,his is calibrated.yours is setup at factory a little fast.get a gps and check it you will see.
Old Jun 17, 2012 | 08:22 AM
X Iron Butt's Avatar
X Iron Butt
This is also why there are so many variances in fuel MPG.
Old Jun 17, 2012 | 08:24 AM
Keithhu's Avatar
Keithhu
Forgot to check it against my GPS. My *speed*ometer does read about 2-3 MPH faster than the GPS at 70 MPH, but I think that was true before I put on a 17.
Does calibrating the speedo affect the odo miles?
Old Jun 17, 2012 | 08:25 AM
twistr's Avatar
twistr
The sensor is in the transmission
Old Jun 17, 2012 | 08:33 AM
Lowcountry Joe's Avatar
Lowcountry Joe
The speed sensor is located in the rear top of the transmission. Anything or any change in the drive train can affect the signal sent to the speedometer by the speed sensor. Changes in rear tire diameter (thus circumference) along with sprocket and pulley tooth count can slightly speed up or slow down the process measured by the speed sensor.
Your front tire is not part of this equation. Confirm actual miles driven and actual speed with GPS, then you will know what is what. Maybe you are right and your bud is wrong. But you won't know til you measure it with a gps.
Old Jun 17, 2012 | 10:36 AM
08FXDC's Avatar
08FXDC
My speedo is about 2-3 MPH faster than my GPS
Old Jun 17, 2012 | 10:46 AM
blarg's Avatar
blarg
most ecu reprogrammers will let you adjust the speedometer. the sensor sends data to the ecu which calculates the speed and mileage based on a pre programmed constant. that constant can be changed.
Old Jun 17, 2012 | 11:27 AM
Keithhu's Avatar
Keithhu
Right, I get that, but does adjusting the speedo calibration adjust the rate at which odo miles accumulate?
Old Jun 17, 2012 | 12:01 PM
Scaredofrain's Avatar
Scaredofrain
I would say "yes". The speed and the odo will recieve their signal from only one sensor. So if the sensor gets calibrated it will affect both speed and accumulated mileage.
Peanuthead
Aug 28, 2017 11:16 AM
htoler
Jul 29, 2015 07:26 AM
kk001234
2014-2024 Touring Models
25
Oct 5, 2014 05:18 PM
harley-jones
Sep 22, 2008 08:02 AM
jeffer60
Jul 2, 2008 02:51 PM
