2003 electra glide
Old Jun 21, 2012 | 11:54 AM
WOODS63's Avatar
WOODS63
Stage II
Default 2003 electra glide
Can you run a wider tire on the rear than a 130? Any help thanks.
Old Jun 21, 2012 | 12:50 PM
mkguitar's Avatar
mkguitar
yes, convert to chain drive and the options open up
mike
bduster's Avatar
bduster
Countless threads re. this, but to re-cap, if you're running the stock 16x3" rear & stock belt/pulley on your '03, you can easily run a MU85B16 or a MU90B16 (appx. 142mm) without any mods, although I did add the Pingle Spacer for a little more clearance between the tire and stock belt. A 150 should work with the spacer & trimming &/or removal of the belt guard, & a 160 can work with a wider rim & the '04-later 1.125" belt/pulley set-up. Wider you go, watch for caliper mount & fender clearance issues as well.
Old Jun 21, 2012 | 01:24 PM
grbrown's Avatar
grbrown
If you have a 1 1/2" wide belt, the widest you will get in is as bduster describes. If you have the later spec narrow belt (which can be retrofitted) a 150/80 will go in. That is the widest some brands will recommend for a 3" rim.
I'm working on a Deuce wheel at present, with a 160/70, but work in progress. Looks promising, but not yet back on it's wheels. Clearances are very snug!
Old Jun 21, 2012 | 01:26 PM
Pumba11's Avatar
Pumba11
The simple answer is you can run a 140 no problem. If MU90B16 if you were going with a Dunlop E3.
But I guess someone may have already said that. Oh well.
Old Jun 21, 2012 | 01:53 PM
WOODS63's Avatar
WOODS63
Stage II
Thanks for the replys. That helps alot. Going to get a new tire today.
Derek_96
Wheels/Tires
Apr 15, 2017 06:47 AM
HOGILAC
Wheels/Tires
Feb 17, 2014 11:58 AM
JIMSFBL
Sep 9, 2011 11:22 AM
GzrGlide
Wheels/Tires
May 24, 2011 06:19 PM
El Chiguete
Dec 8, 2009 10:55 AM
