Brake Pad question
Old Jun 21, 2012 | 07:49 PM
Ultra Pearl's Avatar
Ultra Pearl
Default Brake Pad question
What is the average milage most guys are getting on a set of brake pads (front rear) on an 08 ultra classic under normal braking conditions.
I have 9100 miles and pads look like they are getting worn down. But I don't know the thickness of a new pad.
Old Jun 21, 2012 | 07:51 PM
Dew Me's Avatar
Dew Me
I have 27K on my originals. Started making some noise last year but they still brake fine. I did buy new ones though. Probably going to do the job this weekend.
Old Jun 21, 2012 | 08:01 PM
mrmud4x4's Avatar
mrmud4x4
I got 24k on mine....getting a little worn. I think my manual says change at 25K. (2002 RK)
Old Jun 21, 2012 | 08:10 PM
Lowcountry Joe's Avatar
Lowcountry Joe
The stockers throw out a lot of dust. Consider the Lyndall Zplus or Gold Plus pads. A lot less dust. I got a whole set of Zplus (three pair) on Ebay for $125.
Old Jun 21, 2012 | 08:23 PM
azray7's Avatar
azray7
My bike has 11,000 miles and replaced the pads and installed floating rotors on the front. Getting a slight rub; Harley says its normal...but the noise drives me crazy. Spacers are set right and good. The axle is torqued correct. Pisses me off, if I new a better pad with less dust and quiet, I'd trash my new pads ...already taken it in to Harley and they say it's normal. :-(
Old Jun 21, 2012 | 08:42 PM
Dew Me's Avatar
Dew Me
Yeah, sometimes I turn the engine off a few houses away and coast home. Noisy as f*ck! Don't see how it can be normal, but apparently it is.
Old Jun 21, 2012 | 08:53 PM
MichiganDave's Avatar
MichiganDave
Replaced my fronts at 23,000. They were worn out. Still have the originals in the rear on my 08 Ultra.
Old Jun 21, 2012 | 08:57 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
if you drag your feet a lot, you can get great mileage out of them!!!
on a more serious note, downshifting to reduce brake wear works very well, the downside is clutches are much more expensive than brake pads!!! I don't down shift to slow down, thats what brakes are for!! (I mean for coming to a stop, not slowing down to go into a turn where you are going to use that gear on acceleration)
Old Jun 21, 2012 | 09:09 PM
TWIN CAM 96's Avatar
TWIN CAM 96
22,000 & still have a lot of pad
Old Jun 21, 2012 | 09:17 PM
rkoivisto's Avatar
rkoivisto
Default Front pads
This blows me away. I had an 08 Street Glide that I had 61K miles on and did not need to change the front pads. I replaced the rear pads at about 15K. I do hit the rears first and then modulate the fronts depending on how quick I need to start. I can't believe the fronts would be wore out that quick.
