Heritage bars no good for me-help
Old Jun 25, 2012 | 07:44 PM
dakotared's Avatar
dakotared
Originally Posted by boogaloodude
Heritage bars need to be pulled back enough that your grips are parallel with the ground. The bars will not be inline with your fork legs.
This. I am tall and so I wanted the grips as high as possible. I pulled them back just a bit past being in a straight line with front forks. Grips are now parallel with the ground. Comfortable now. Wish the grips dropped a bit more at the tips but for the $$, this was the solution for me.
Old Jun 26, 2012 | 01:11 AM
bklynbob's Avatar
bklynbob
I've got Khromewerks 300044 bars. Very similar to the 56569 bars,about an inch wider and higher,drilled for internal wiring and tbw ready.
Old Jun 26, 2012 | 04:31 AM
Jinks's Avatar
Jinks
Get your local dealer to let you hold a set of "Wide Glide" bars next to your Heritage bars. The same height but a different wrist angle. Cables & wiring fit the same.
Old Jun 26, 2012 | 06:27 AM
rubberfrog's Avatar
rubberfrog
good info
Old Jun 26, 2012 | 07:36 AM
Flhrhog's Avatar
Flhrhog
I think I will try the sweepers +2, order them and see what the wrist angle is like and send them back if no better than I have. I also like the 300044 also. Might try them too.Thanks to all.
Old Jun 26, 2012 | 07:38 AM
Dagsadoo's Avatar
Dagsadoo
I had similar problems and ended up putting on the HD 12" mini apes. Love the setup, have done several 5-600km a day rides and not a problem.
bigdave367
General Topics/Tech Tips
Apr 16, 2015 09:40 PM
klaybus
Nov 7, 2011 05:51 AM
davidsdad
Aug 29, 2011 07:45 AM
dblt74
Jan 9, 2009 07:05 PM
dognut
Feb 12, 2007 11:23 PM
