inner primary
Old Jun 25, 2012 | 09:31 AM
ehale3's Avatar
ehale3
Default inner primary
will a 2006 inner primary with the auto adjuster fit and work on a 2003 ultra 88ci ?
Old Jun 25, 2012 | 09:36 AM
Guntoter's Avatar
Guntoter
A 2006 Touring inner would normally have the manual adjuster, unless someone changed it to an automatic. 2007 and up are the ones designed with the auto adjuster. 2007 and later will not fit the 2006 and earlier, the bolt pattern mounting to the engine is different and I suspect to the transmission also.
Old Jun 25, 2012 | 10:06 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Are you just looking to get the adjuster? Or is your inner primary busted?
If you just want the auto adjuster it will fit your primary case. http://www.harley-davidson.com/gma/g...bmLocale=en_US
If you want the newer case.... then No, I don't think it will fit.
Old Jun 25, 2012 | 09:18 PM
ehale3's Avatar
ehale3
I just wanted the auto adjuster.I found one on Ebay for $40 and thought it would be worth it if it fit.
Old Jun 25, 2012 | 09:21 PM
shooter5074
If it's the Harley part...... it will fit. You will have to open up your primary to install it. It won't fit through the inspection cover hole.
It's hard to go wrong for 40 bucks......... unless the ramp is worn out.
imboden
Jul 31, 2016 07:16 PM
rideevo
Mar 17, 2013 05:50 PM
goosehead
EVO
Nov 8, 2011 03:13 PM
Stiched
Touring Parts
Nov 1, 2010 10:25 AM
buzzpat1
Jun 29, 2009 03:32 AM
