carbon buildup on pistons
Old Jul 4, 2012 | 10:00 PM
MOSTWANTED's Avatar
MOSTWANTED
Default carbon buildup on pistons
I pulled the spark plugs this weekend to inspect them for tuning issues/age/condition and they looked great but I noticed a what looks to me like a lot of carbon buildup on top of the piston thru the spark plug hole. I know I can't really see in there real well but I know that the top of the piston looks black, rough, and pitted. What does this mean? Is there anything I can do short of tear down and rebuild to clean it up? Maybe seafoam in the tank for a few tanks?
Old Jul 4, 2012 | 10:03 PM
soft 02's Avatar
soft 02
Usually there is a fair amount of black carbon on the piston. Yea run some seafoam but wouldnt loose sleep over it. Does it run good? Ping, knock ect?
Old Jul 4, 2012 | 10:06 PM
btsom's Avatar
btsom
Do some reading at "toptiergas.com" and decide if you might want to spend a little more for gas that meets the top tier requirements. It is supposed to keep combustion chambers and intake valves clean (or as clean as any gas can).
Old Jul 4, 2012 | 10:15 PM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
Run motor until normal operating temp. Remove air cleaner and spray a mist of water into the intake while bumping throttle to keep motor running. Make sure pipe is pointed in a safe direction, as itwill be shooting a bunch of black stuff out of it. This will clean your combustion chamber, and will do no harm to the motor, but you will not notice any difference in the way it runs.
Old Jul 4, 2012 | 10:18 PM
soft 02's Avatar
soft 02
Both great suggestions. I used to pour water down the carb with the truck on a outdoor dyno and watch the black soot shoot out the tail pipe!
Old Jul 4, 2012 | 10:19 PM
dbell66253's Avatar
dbell66253
Unless its an unusual amount, I wouldn't be to worried, the top of a piston stops looking new a lot faster than you may think, probably within the first 1k miles. As long as the bike is running with no issues and your doing proper maintenance, you should be ok.
Old Jul 4, 2012 | 10:46 PM
MOSTWANTED's Avatar
MOSTWANTED
OK, I think I'll just not worry about it then and forego trying to "wash" my pistons with water. It seems to run fine really. Not saying that it doesn't work or that I don't believe you, I'm just not going to worry about it. I will try the seafoam in the gas tho to help maintain fuel system and valves. Thanks.
Old Jul 4, 2012 | 10:56 PM
Arizona's Avatar
Arizona
Thanks for that link. Interesting, I've heard this is the case but didn't know WHICH were the top tier for certain. I've been using Chevron and Shell mostly since I've heard good things about their additive packages.
Old Jul 4, 2012 | 11:02 PM
soft 02's Avatar
soft 02
99% of the time I use Chevron because of the Techron. Been doing this for decades.
Old Jul 4, 2012 | 11:16 PM
btsom's Avatar
btsom
On occasion, Shell publishes little pamphlets with helpful hints and at the end it says if you have more questions call.... I called and asked what this "added nitrogen" thing was all about as the air going through the engine is already about 80% nitrogen. She said it wasn't THAT kind of nitrogen. I knew when to stop talking before I asked how many types of nitrogen there were. I think Shell is good gas but their advertising makes me wonder sometimes.
