I already knew that, I set it up properly and ride it fast and hard, it had a wobble in fast corners before I sorted out the tire pressures and front forks.
Listen to the children as they play ain't it Kinda of funny what the children say. Skip a rope
Graham, I appreciate your time and comments, and especially the PMs to help me sort out my particular issues. I for one, really appreciate all the time and energy you've spent on this issue. Thanks.
Wow. Everytime I think I'm about done with the mods, another thread like this one pops up. I've never expereinced the wobble, but I'd much rather do something proactive about it. You've got me thinking about it, sir, so I thank you for that.
Mr Brown
alittle off the track but
Have you ever owned, ridden or spent time with a BMW with a boxer engine? THe flat twin creates a an oscillating movement pattern over the entire bike on idle. At high revs that obviously levels out quickly. I wonder how your last quote of Buell plays out relative to a Beemer flat twin.
sorry to diverge from the OP......just a little science.
Wobbles occur on many types of bikes for many reasons. Most are created by a perfect storm of worn parts, tires, and tire pressures. Could Harleys be design improved? I am sure. Is it inherently unsafe...my opinion is no. As most of us have not had wobble issues. I still maintain that the OP is of great value for all who are not only performance oriented but concerned with safety.
thanks again Mr Brown
I've owned BMW bikes almost as long as I've owned Harleys, including two R100RSs, one from new. Those engines are bolted in solid and do not use any form of rubber mount system. The system designed by Buell is expressly intended to allow the engine to move on it's mounts, so it doesn't relate to BMWs.
The pistons of a flat twin (indeed any flat engine) move in opposite pairs, so they are balanced, one piston against the other. There are other out of balance forces in a flat twin, but they are not as big as in our V-twins, so they don't need the same level of vibration isolation.
Wobbles in other bikes are largely down to other design short comings. The solid mount Glide frames that pre-date the first FLTs were just plain flexible, not stiff enough! I did my time on them.....
