Bagger wobble exposed!
Old Apr 24, 2024 | 09:12 AM
  #761
Highway Handler's Avatar
Highway Handler
Originally Posted by roussfam
A lot of people don't like the comment I'm about to make. How fast are you going in this sweepers that you get a wobble? Serious question, are you driving like a Grand Prix driver?
I've never experienced this on my 07 I've been told it's because I'm not going fast enough
It is a real thing, and not necessarily from high speed.
Speed has something to do with it, but more importantly something else is worn or not aligned. I rode an Ultra Classic that had it bad, it was no fun. The bike felt “loose”
I had a Honda CBX that had it bad, it was fixed by new rear shocks.
My Road King does not have the wobble and rides great on stock shocks.
If you are riding the bike and it feels like something isn’t right, then something isn’t right.
Old Apr 24, 2024 | 09:43 AM
  #762
Dr.Hess's Avatar
Dr.Hess
Hey, FT, are you the FT from a certain automotive magazine related site from years ago?
Old Apr 24, 2024 | 09:53 AM
  #763
CaffeineBuzz's Avatar
CaffeineBuzz
this is amazing
after all of these years, this thread is still alive, the OP painstakingly layed out, ad nauseum, every possible detail and fact he could find about wobbling
just so that after 12 years, a stranger like me could come along and say...
"**** that, I'm not reading that much!"
Old Apr 24, 2024 | 04:36 PM
  #764
roussfam's Avatar
roussfam
Originally Posted by foxtrapper
It didn't take a lot of speed to set my 04 to wobbling. Basically heeled over in a sweeper turn and then hit some expansion joints to bounce the bike a bit sideways since it was leaned over in the turn.
Was, and wasn't, a simple issue and fix, on my bike.
One is the was too loose steering head. A whole lot of the wobbling the bike had was right there, flopping easily around that hinge joint. Judicious use of arm strength damping helped a whole lot, as did a mildly tighter set to the free play. Never did install a steering damper, but it certainly could have helped.
Another was the built in oem slop in between the swing arm pivot shaft and the inner bearing inserts in the swing arm. Easily and obviously detected with the belt slack, but invisible with tension on the drive belt. That slop let the rear wheel turn side to side, with the belt acting as a rubber band. Eliminated that play and the bike never acted up again. Not on the highway, not on the track.
Got it, I had a speed wobble in the front end, tightened the steering head bearings and that took care of that. Haven't had any issues with my rear end (Buzz, never mind )
Old Apr 24, 2024 | 06:52 PM
  #765
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Yep! That be me.
Old Apr 24, 2024 | 08:56 PM
  #766
roussfam's Avatar
roussfam
I know it's an issue that people have experienced, but like your Road King, mine rides fine. But I will add "so far" lol
Old Apr 24, 2024 | 10:01 PM
  #767
hattitude's Avatar
hattitude
Originally Posted by CaffeineBuzz
this is amazing
And yet you felt the need to take the time and make a negative comment about it....
Old Apr 25, 2024 | 05:19 AM
  #768
roussfam's Avatar
roussfam
Speaking of which....
Old Apr 25, 2024 | 09:46 AM
  #769
Dr.Hess's Avatar
Dr.Hess
Yep! That be me.
Excellent! Good to see you again!
Old Apr 25, 2024 | 11:26 AM
  #770
CaffeineBuzz
i was just clowning around with an old thread, no harm meant
wastedranger
Nov 13, 2019 03:51 PM
FLHTKONE
2014-2024 Touring Models
May 4, 2014 01:42 PM
98fat
May 20, 2011 04:42 PM
Jeff595
Oct 15, 2010 11:32 AM
magna3500hd
Jan 7, 2007 08:21 AM
