Bagger wobble exposed!
Old Aug 17, 2014 | 10:10 PM
  #451
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by Dun Roamin
Do you think there is any merit to bracing the frame at all, e.g. the later baggers have a light brace across the front downtubes?
Or do you think the frame is rigid enough to cope? I know your experience is "don't worry about it Graham" and I am sure you are right.
I'm going off to measure the free play on my pivot ... it certainly rattles and I remember Hillside (?) saying they re-machine theirs to a fine tolerance or running fit.
Without doing analysis of the frame and it's rigidity, I cannot honestly or accurately say either way. About the closest I can come to giving an answer is to say I've yet to find a frame on any bike that I thought was too rigid.
Old Aug 18, 2014 | 02:31 AM
  #452
4_stroke's Avatar
4_stroke
Originally Posted by bwoltz
Nothing..
Nope..
The FXR frame is pretty much identical to the the bagger frame except that the changed the geometry in the front and added a bunch of weight....
Check again.... The FXR has an additional crossmember that would make a significant difference to the rigidity of the frame.
Old Aug 18, 2014 | 06:55 AM
  #453
Dun Roamin's Avatar
Dun Roamin
Yup, I've wondered about that. IT has a cross member under the engine/transmission ... but it is to brace or just to attach the jiffy stand too? (Honest question).
The later baggers also have a brace across the front downtubes and a larger plate at the rear where the center fitting stabilizers attach.
Old Aug 18, 2014 | 07:03 AM
  #454
4_stroke's Avatar
4_stroke
It mounts the mid controls and centre stand. It is much more substantial than the rear crossmember.
It would be an interesting exercise to get a bike that "wobbles" and fit a crossmember where the FXR has one and see if this has an effect. The solution to all these problems may just be a bolt in brace on the frame where the FXR has one (and they don't wobble!)
Old Aug 18, 2014 | 07:55 AM
  #455
grbrown's Avatar
grbrown
Cool
Originally Posted by skypilot_one
Does the rear stabilizer prevent twisting along with side to side motion?
No, the top stabiliser between the heads does that. However motion arising from the lack of a stabiliser, say in a fast bend, may well feel strange in all manner of ways!
Old Aug 18, 2014 | 01:10 PM
  #456
Max Headflow's Avatar
Max Headflow
Where?
The late baggers have the whole rear section boxed in where the FXR has an oil tank..
Bottom side both have cross braces that keep the frame from spreading and act as a sheer panel. FXR might be a little wider there..
Old Aug 18, 2014 | 01:23 PM
  #457
4_stroke's Avatar
4_stroke
Where?
So the FXR has a different frame stiffness to the baggers near tbe rear mount. The centre crossmember helps tie in the bottom frame tubes with a boxed section not just a thin flat plate with single line of weld as at the baggers have at the rear.
One way to check the frame stiffness in this area is ondo the bolts that hold the rear mount plates in place untill you have lost the preload. Take an accurate measurement of accross the frame then bolt the plates up again to see if it has spread the frame at all when the preload comes back on again.
Old Aug 18, 2014 | 01:57 PM
  #458
grbrown's Avatar
grbrown
The FXR and Touring frames are similar, but not the same, the FXR is more compact. So with or without additional bracing they are going to behave differently and have different degrees of stiffness.
Old Aug 18, 2014 | 03:27 PM
  #459
Keithhu's Avatar
Keithhu
I had the True Track installed at Sturgis on my '13 Fugly. My conclusion is that its a subtle but welcome improvement.
Old Aug 18, 2014 | 06:49 PM
  #460
Max Headflow
Mid controls mount to the side tubes not the cross members.. Not sure it make much diffference in stiffness as it is a smaller box and it is pretty far from the swing arm pivot.. I know a guy that claimed it helped keep the frame from pinching there... Not sure I believe that..
