Got Ping?
Old Jul 19, 2012 | 01:21 PM
mgmmgm's Avatar
mgmmgm
Default Got Ping?
Called the tuner that tweaked my RK June 20th, still have been experiencing the PING beast. So, it's nice out weather wise, but I think I will hold off until the shop can assess my tune on the 7-25. to ride.
The sound of someone firing a BB gun into a tincan does not thrill me when I twist the wick, and i am a little paranoid I suppose of causing damage to pistons etc., riding the bike with this happening.
Hopefully the tuner can pull out some timing and fix the issue. I do not have the SE tuner software, i would be lost trying to do any map mods myself.
Maybe, if i was running a power vision tuner I could get the issue fixed without having to spend dyno time again...
Old Jul 19, 2012 | 01:44 PM
mkguitar's Avatar
mkguitar
have you considered adding nightrider.com xieds.
either as a temp or permanent fix.
probably under $130, plug right in
mike
Old Jul 19, 2012 | 02:12 PM
2black1s's Avatar
2black1s
mike
While altering the AFR (which is what the xied's do) may help in some cases if the pinging is very minor and isolated to the closed loop portions of the map, most cases will require a timing adjustment.
If you have pinging at WOT (or twisting the wick in the OP's words), xied's will do nothing for that.
Old Jul 19, 2012 | 02:33 PM
TUCCI's Avatar
TUCCI
Dont try a dyno to remove a ping do it yourself. If your tuner allows you to get into the timing all you need is 1)what speed & RPM ping starts and stops. 2) access to the timing map on your tuner and 3)Patients to remove it cuz its going to take some trial and error. Let me know how I can help.
Sparra
Jul 16, 2013 05:26 AM
markwolula
Apr 29, 2012 06:57 AM
103Eagle
May 12, 2010 06:51 PM
kdubcr250
Jan 31, 2010 08:48 PM
kazanimo
Oct 25, 2009 08:25 AM
