drivers backrest
Old Jul 21, 2012 | 11:57 PM
rperk60's Avatar
rperk60
Default drivers backrest
I am going to install an adjustable backrest on my ultra. Removing the seat is the only thing i will need to remove correct?
Old Jul 22, 2012 | 12:25 AM
Challenger's Avatar
Challenger
As far as I know. You would be correct
Old Jul 22, 2012 | 12:28 AM
drukanfu's Avatar
drukanfu
After the seat is removed their are two self threading screws that hold the front of the backrest bracket on. That's all, just don't over tighten those two screws. They are the self tapping type in thinner metal.
Old Jul 22, 2012 | 12:35 AM
Tek74's Avatar
Tek74
It literally only took me 10 minutes to install may Mustand driver backrest. I spent more time adjusting it to Perfect in terms of up/down and front/rear.
Old Jul 22, 2012 | 12:53 AM
Big E1's Avatar
Big E1
Quick and easy. Best mod.
Old Jul 22, 2012 | 08:30 AM
Pete6114's Avatar
Pete6114
I'm installing a adjustable back rest today myself. Was looking over the instructions yesterday and looks like a piece of cake.
I'll get to use my new inch-pound torque wrench/s.!
Old Jul 22, 2012 | 08:36 AM
jeffreydsilver's Avatar
jeffreydsilver
Default Road Sofa!
I installed the Harley adjustable drivers backrest on my 09 Road King. The only advice I would have to pass along would be to install the backrest base loosely (without tightening) at first and then take apart 1 bolt at a time to locktite individually before tightening. Great mod! I love my Road Sofa!
Old Jul 22, 2012 | 08:42 AM
ericl's Avatar
ericl
On my 2010 road king the two studs are mounted to a plate, the fender has two holes that the studs pass through from underneath, mine are/were not screwed into the fender. I replaced my stock with an extended Sinister fender, and reused the studs.
Old Jul 22, 2012 | 08:49 AM
HTNHARD's Avatar
HTNHARD
Yep. Depends if you have to mount the adjuster for the adjusstable one. Bout as easy as turning the ignition on and hitting the starter button.... and flicking the kill switch to run.
jimcb1
Apr 25, 2018 12:35 AM
Sandcrab
Jul 27, 2011 08:15 AM
Dynk
Apr 9, 2009 08:13 PM
Bubba Zanetti
Nov 19, 2006 10:22 PM
zlaneb
Oct 19, 2006 12:12 PM
