Little help please.
Old Jul 22, 2012 | 02:47 PM
TSAVO's Avatar
TSAVO
Default Little help please.
OK my right side turn signal does not work. The front running light works but neither it or the rear indicator will flash. the left side works as it should front and rear. The security light will also not go off even after the bike is started. the left signal also flashes 5-6 times after I turn on the ignition, I imagine all 4 would probably flash if the right side was working. The manual says that if the security light stays on that there is a trouble code present, is there a way to retrieve these codes myself? Thanks in advance for any help, I've had bikes my whole life, but I'm a newb to the Harley world so I still have a lot to learn.
Old Jul 22, 2012 | 03:15 PM
TSAVO's Avatar
TSAVO
Never mind, I'm an F-Tard, found the problem. It was all me. I'll explain later after I hopefully fix it. LOL
105FX
Aug 5, 2018 08:00 AM
k-weaver
Jan 31, 2017 06:58 AM
Bill03E
Sep 17, 2015 05:21 PM
benjitellez
Mar 21, 2013 11:30 AM
Neo
Mar 18, 2007 09:36 PM
