First off, I have a manual.
Anyone else do an oil change on a 103 and find that 3.5 Qts of oil brings them over the full line on the dipstick?
I always warm up my motors and then let them sit before changing the oil.
3 Qts would probably put me in the middle of the dipstick.
The sumps on these bikes hold a lot of oil. There is a scavanger I've seen advertised that's supposed to remove all old oil.
I usually add three quarts and a little to the filter. I also try to leave the plug out overnight . When I fill the cold engine about 1/3 down stick from full.
Oil kicking out the breather onto the engine and clothes is no fun.
Are you checking it with the bike upright and level???? On my 05 it takes exactally 4 quarts with filter and the level is right at the full line on the dip stick.
I can't comment on the 103" as I have an 09 96" but I drain the oil while on the jiffy stand. I have found that 3.5 is always perfect for me. I've tried draining and then standing the bike upright to get more out, didn't make a difference.
I changed mine yesterday (96TC) filter and change i just pour 4 quarts in. 72000 miles on the bike, 4000 miles and the oil was nasty.....My owners manual said to use 4 quarts so that is what i have always poured in. I think the ctank area and oil tank are the same on a 103"
I have a 12 Streetglide and mine is the exact same as yours. I changed mine last week. Bike was hot, let it drain until stream of oil stopped. It took a little over 3 quarts to bring it up to the full mark. Checked it several times since and it's still on the full mark.
