I installed Hog Tunes front speakers and amp about a year ago. Never had a problem until recently. My problem is when the motor is running the left speaker cuts in and out, basically static. It does not do it all the time. I checked the wiring connections on the speaker. I have traced my ground all the way back to the battery everything is clean and tight. If I shut the motor off it sounds fine. Any suggestions??
Static might come from poor grounding, you can try running a ground wire from that speaker direct to a frame bolt, or battery negative.
Even changing the length of the wires to that speaker can help. Wire can act as an antenna, and antennas are tuned for specific frequencies, the speaker wire may be picking up RF and interfering with that speaker.
I have a biketronics amp and speaker package all the wires have been modified to custom lengths and soldered. All connections are fine I've been through the forums thoroughly and I'm not the only one having this issue. It's happening with multiple amp and speaker packages. My next step is to run a ground directly to the battery. And it only happens when it's running which makes it more difficult to find the problem.
Does that amp setup use RCA cables or just wired in to the radio? If RCA cables, try new ones. It's generally not a good idea to ground the amp at the battery due to potential ground loop issues but if you have had it this way all this time and your problem just started, that's probably not the problem.
My best guess if all connections are good would be a grounding problem inside the amp or maybe a cold solder joint in the amp.
Agree completely. A cold solder joint internal to the amp is likely the issue especially if many people are having similar issues.
I should've added that a cold solder joint is a soldered joint on the board that has some impurity in the solder itself. these amps are mass produced it isn't unreasonable to think that something in the manufacturing process is resulting in a faulty joint at a particular circuit on the board.
My RCA cables were good and all my solders were good I sent the radio off to iron cross audio and had RCA preamps put on it and had them give it a once over. The preamp sound way better than the RCA converter's. I'm pretty sure it was the radio and not the converters. Because I actually remember it cutting out before the amp I think the amp just amplified it to where you could hear it end it wasn't noticeable before because it wasn't loud enough
Well did it solve your problem when you sent the radio in to Iron Cross?
