Fairing vibration
Old Jul 24, 2012 | 04:51 PM
cdavis1075's Avatar
cdavis1075
Stage III
Default Fairing vibration
I have a 07 streetglide with a nasty vibration at idle, the front motor mount looks ok .Ideas ?
Old Jul 24, 2012 | 04:54 PM
foghorn's Avatar
foghorn
Inner fairung bracket could be broke. I had an Ultra do that, mainly on right side. Bracket was broke
Old Jul 24, 2012 | 04:57 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
Check the fairing brackets. They've been known to break!
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old Jul 24, 2012 | 04:58 PM
Nute's Avatar
Nute
Yup broken mount on inside of fairing. Check the supports on both sides right by the speakers. Lots of guys make up brackets that seem to work out of angle iron but this guy sells some that work great and are easy to install for a fair price.
http://www.nwmachine.com/rfw//Gallery.htm
Checkout the video on his website. If anything it will tell you where to look.
Old Jul 24, 2012 | 05:04 PM
cncmike's Avatar
cncmike
I thought my bracket was broken, but when I opened it up I found a missing screw for the speaker bracket. I was afraid to over tighten them when I changed speakers. Now I use a drop of locktite.
Old Jul 24, 2012 | 05:05 PM
cdavis1075's Avatar
cdavis1075
Stage III
The motor seems to shake more than normal in the front. the rear of the motor is tight but the shifter is bouncing like crazy, I think its more than fairing brackets
Old Jul 24, 2012 | 05:09 PM
jmbaker3's Avatar
jmbaker3
harley has improved the bracket. be sure to get the latest.
Old Jul 24, 2012 | 05:13 PM
Stiggy's Avatar
Stiggy
Does the vibration subside over 2,000 rpm, or just get faster?
Old Jul 24, 2012 | 05:14 PM
Nute's Avatar
Nute
If it's not the bracket. Check your motor mounts.
Old Jul 24, 2012 | 05:30 PM
AnotherBlackSG's Avatar
AnotherBlackSG
Did this just start outta nowhere or is it a new bike to you and just something you noticed about it?
If it just started suddenly, like everyone said, look under the fairing first. Then go to the motor mounts.
If its a new bike to you, it's probably just the nature of the beast. My 08 used to vibrate so bad at idle, that I couldn't see out of my mirrors. I replaced the front mount with a GlidePro and it made a huge difference. Far from smooth, but at least bearable now. I plan on doing the rest of the system this winter.
http://www.glide-pro.com/stabilizing-system/
