CLICK when turning key to lock on 2012
Old Jul 29, 2012 | 11:03 PM
HDJIM1158's Avatar
HDJIM1158
Default CLICK when turning key to lock on 2012
I noted that when I turn the lock to Fork Lock on my new 2012 I hear a CLICK. Is this normal ?? And if so, what is causing the noise ???
I should have been more clear, the CLICK appears to be coming from the gas tank/ appears to be a electrically click.
Thanks in advance, Be Safe JIM
Last edited by HDJIM1158; Jul 29, 2012 at 11:15 PM. Reason: Making problem clearer
Old Jul 29, 2012 | 11:04 PM
Casper's Avatar
Casper
The click is the lock popping out, if you ever take your ignition out you'll see what I'm talking about.
A small click is normal.
Old Jul 29, 2012 | 11:12 PM
Buzzard42's Avatar
Buzzard42
I heard the same on mine the first few times I tried it. Its gone away after using it a few times, but don't acctually use it much.
Old Jul 29, 2012 | 11:13 PM
HDJIM1158's Avatar
HDJIM1158
Old Jul 29, 2012 | 11:28 PM
MYCRISIS's Avatar
MYCRISIS
I believe what you are hearing is the locking pin engaging the frame to lock the steering. It's spring loaded and makes a pretty loud click.
Old Jul 29, 2012 | 11:31 PM
dlongo8241's Avatar
dlongo8241
normal, mine does the same thing...
Old Jul 30, 2012 | 12:14 AM
V2Evo96's Avatar
V2Evo96
Don't worry-- what you hear is not electrical. It's just the lock pin dis-engaging.
Old Jul 30, 2012 | 05:47 AM
HDJIM1158's Avatar
HDJIM1158
Thanks, Just wanted to make sure.. My 2009 was never so loud.
Be Safe JIM
salty_rider
Apr 23, 2015 08:30 AM
salty_rider
Touring Parts
Apr 23, 2015 08:27 AM
Bythebuffalo
General Topics/Tech Tips
Apr 1, 2013 07:32 AM
JackD
May 1, 2010 12:40 AM
TampaJim
Nov 9, 2006 10:33 PM
