Compare 2009 RK With 2010 RK
Old Aug 4, 2012 | 08:21 AM
dobro's Avatar
dobro
Default Compare 2009 RK With 2010 RK
To get the greater seat height plus the improved chassis on the 2009 and 2010 RK Classics I've decided to buy one of them. Please point out significant benefits and problems each has compared to the other. Thanks.
Old Aug 4, 2012 | 08:23 AM
dswansbiker's Avatar
dswansbiker
09 to 10 changes were minimal. 5th gear went from straight cut to helical in 2010. This reduced the whine in 5th that annoyed some.
Old Aug 4, 2012 | 08:44 AM
mmcbeat's Avatar
mmcbeat
The '09 will not have a cat.
Old Aug 4, 2012 | 08:53 AM
OldPhat's Avatar
OldPhat
Price
Old Aug 4, 2012 | 09:02 AM
ocezam's Avatar
ocezam
It also reduces the strength of 5th gear. I can live with the whine...
Old Aug 4, 2012 | 09:53 AM
mkguitar's Avatar
mkguitar
unless a California or export model.
o2 sensor size is different 09/ 10+
but much the same animal.
if you google
2009_model_year_technical_forum
you will see the changes into 2009 from 2008.
then substitute 2010 ( and 2011 if you want) and you can track the ongoing changes
and you can also decode the VIN to see if you are looking at a CA model.
mike
Old Aug 4, 2012 | 10:05 AM
dobro's Avatar
dobro
Since the 2009 does not have a catalytic converter does it run cooler than the 2010? In which other ways does the absence of a cat effect a 2009?
Old Aug 4, 2012 | 10:26 AM
Airborne350G's Avatar
Airborne350G
If both are stock the 09 will be cooler with out the CAT. The 5th gear whine, do not hear it on my brother 09 Ultra.
Old Aug 4, 2012 | 10:46 AM
Iceman24's Avatar
Iceman24
Originally Posted by Airborne350G
If both are stock the 09 will be cooler with out the CAT. The 5th gear whine, do to hear it on my brother 09 Ultra.
^^There's your answer-agree^^
Old Aug 4, 2012 | 11:07 AM
Texas Fat Boy's Avatar
Texas Fat Boy
2009: The 5th gear whine means nothing.............some guys just want to bitch
2010: They started putting the Catalytic Coverter in the headers of all Touring models
otherwise check them out here
2009: http://www.totalmotorcycle.com/photo...ingClassic.htm
2010: http://www.totalmotorcycle.com/photo...ssic-FLHRC.htm
