power commander V install
Old Aug 5, 2012 | 08:13 PM
shortcircuit62's Avatar
shortcircuit62
Default power commander V install
i would like to use the "ACCY" switch on my dash to switch between " eco" and power " map i know its got to be a spst switch ,,how do i remove voltage from that switchand just use the switch as "dry " contacts,,,thank you in advance
Old Aug 6, 2012 | 12:00 AM
slhanks4's Avatar
slhanks4
I'd think you could just disconnect the leads to the switch under the switch panel.
Old Aug 6, 2012 | 12:17 AM
stuart1270's Avatar
stuart1270
Hook it up through a relay from the accy connector under the seat. also if you know how the accy connector works one of the pins is only powered with switch on. If you need a diagram for relay set up let me know.
Old Aug 6, 2012 | 09:49 AM
slhanks4's Avatar
slhanks4
BTW, I am curious about the map switch. Did you buy the kit from Dynojet or are you building your own? If so, where did you get the connector to plug into the PCV?
Old Aug 6, 2012 | 11:13 AM
TUCCI's Avatar
TUCCI
I remember reading something about that in the paper manual that came with the unit am I wrong?
Old Aug 6, 2012 | 11:25 AM
JustDennis's Avatar
JustDennis
I used the PCV several years ago before switching to the PowerVision. Last night, I was in the garage and found the "switch", I used to flip between maps. It has the connector to plug directly into the acc plug, a relay to flip the switch when you appy power via the acc switch and two wires that just plug into the PCV (no power just completes the circuit as the PV needs).
The switch worked well with the PCV, I had a power map and an economy map
Old Aug 6, 2012 | 08:28 PM
shortcircuit62
slhanks i was looking pcv and it says it features two map settings and a spst switch is what was needed,, i am NOT building one ( i dont think i could ) im going to buy one
Almostinvincible119
Jul 11, 2023 03:38 PM
shortcircuit62
Jul 11, 2012 09:11 PM
Mal74
Mar 23, 2011 09:30 PM
HOGNOT
May 15, 2010 02:41 PM
THABULL
Sep 15, 2008 05:54 PM
